Go Back   Home > Forums > Amplifiers > Class D
Old 8th March 2007, 05:54 PM   #1
Default New SI T-Amp, Different internals
I got my amp about two weeks ago. I'm quite pleased with the sound. I just took it apart this morning and discovered a few differences. For one, the PCB on the pot has different printing on the top. The circuit seems to be the same configuration. The biggest mystery are these two metal donut shaped pieces. The speaker wire connections out of the main PCB are wrapped around them twice, then soldered to the terminals. They are glued on to the chassis, on the outer wall of the battery case. From what I can tell, looking at other pictures of dissassembld t-amps (TNT audio and the T-amp gallery) these must be new. Anyone know anything?
Old 8th March 2007, 05:59 PM   #2
Fenris is offline Fenris  United States
They're ferrite beads to reduce RF emission. Many class-D datasheets recommend them.
Listen to the music through the stereo, not the stereo through the music.
Old 8th March 2007, 06:12 PM   #3
Why were these not included in the earlier versions? When did they show up? And finally, should I incorporate them into my rebox? I haven't read about problems with RF interference.
Thanks for the answer.
Old 9th March 2007, 12:09 AM   #4
Pano is offline Pano  United States
Pano's Avatar
Those are some hefty ferrites. Bigger than the output inductors!
There are most likely there to reduce RFI.
Take the Speaker Voltage Test!
Old 9th March 2007, 12:50 AM   #5
EdT is offline EdT  Canada
Proberly a CE requirement if they want to be shipped to the UK.
Old 10th March 2007, 05:13 AM   #6
So, when I rebox it, should I incorporate the ferrite rings? Has anyone had trouble with RF?
NAIM 32 internals pat allen Solid State 1 19th August 2008 02:56 AM
tda2007A internals ? ash_dac Chip Amps 3 9th July 2006 07:02 AM
question on amp internals duece212 Car Audio 6 9th March 2006 06:48 AM
Oh help me , geat know-it-all's ! (fix internals of amp) istari knight Solid State 2 20th October 2005 08:27 PM
PCDP with i2s internals? fcserei Digital Source 0 5th December 2002 02:58 AM
Page generated in 0.08777 seconds (72.94% PHP - 27.06% MySQL) with 11 queries
