| Class D Switching Power Amplifiers and Power D/A conversion |
Banned
Since there have been so many questions on how to hook up two batteries to the AMP4 and Teac A-L700p amp, I thought I would post a diagram that I drew that has worked out well for my Teac tripath amp. In order to run the batteries in series and charge in parallel, a 3DPT switch is necessary. The diagram is pretty primative, but it is the best I can do without access to any schemetic software. I hope this helps the people that have asked in the past and have not gotten a response.
#2 |
This seems like it would work, but can anyone confirm this before try this on my Teac amp? I don't want to fry my chip or blow up a battery.
#3 |
I have tried out the circuit above for my TEAC amp and nothing blew up. There is one issue though. The problem I am running into is the regulator reads negative 0.6 volts. When I disconnect ground from my 4 pole Jensen capacitor for the 25v line, then I get 5 volts fine from the regulator. Could someone give some pointers into how to fix this problem?
#4 |
I figured out the problem. Boy does this amp sound awesome with the Jensen PIO caps and Jensen four pole cap. I realized the problem was simply connecting the negative off the cap to the main ground line. Tripath said to keep the 5v and 24v ground lines separate, but with a battery supply this is impossible as far I know. The grounds need to be connected. The circuit is safe and sound. Thanks Newbie23 for the schematic.
#5 |
For the record, many battery chargers have completely floating outputs. In this case, you can use two chargers and avoid the need to switch from series to parallel and back. Simply connect one charger to each battery, and run the chargers from a power strip which you turn off during listening.
I did this with a +/- 24V supply I put together for a UCD project that is still materializing - 4 chargers is a bit pricey, but I knew that without the 'one switch' charging option the setup would be way too inconvenient. I still have the 4x33aH agm batteries though, and trying battery power into my AL700P is something I need to try. |
| FS battery powered RWA Teac A-l700p | wendell | Swap Meet | 3 | 23rd June 2008 11:33 PM |
| Where to get Teac A-L700P??? | ws2k | Class D | 2 | 17th October 2006 11:46 PM |
| How to correctly connect 24vdc battery power to Teac A-L700P??? HELP!!! | Crazy_D | Class D | 2 | 10th October 2005 08:16 PM |
| Help on Teac A-L700P using battery power | HolyGhostFire20 | Power Supplies | 1 | 28th July 2005 04:42 PM |
| Teac A-l700p mods | HolyGhostFire20 | Class D | 0 | 26th July 2005 07:32 AM |
| Page generated in 0.09131 seconds (69.60% PHP - 30.40% MySQL) with 11 queries |
