Go Back   Home > Forums > Amplifiers > Class D
Old 7th March 2007, 04:39 PM   #1
Default TDA8931T question
This is class D amp and my question is has anyone build it and if there were some problems with components? How does it sounds etc...
btw: Does anyone have a pcb??'
Greatings
Old 7th March 2007, 07:13 PM   #2
Nobody?! Don't tell me that all you do is just modding kits and so. Cause this sucks!!!! What about making your own pcb at home and assemble it!!!!!
DIYAUDIO YOU DISAPPOINTED ME!!!
Old 7th March 2007, 07:51 PM   #3
FastEddy's Avatar
" ... Cause this sucks! ..."
Might it be because the chip sucks?? THD = 10%, 8 or 4 ohms ... maybe there are better chips out there and maybe Phillips has improved this since 2004, but it looks like the best place for this one is in a portable radio.
Old 8th March 2007, 05:43 AM   #4
IVX is offline IVX  Russian Federation
IVX's Avatar
This is just a power comparator chip, with single disadvantage -little power. The chip is ready to give you outstanding specs (THD .00* i.e. 100 times better tripath etc), if you ready to implement it properly.
Best regards,
E1.
Old 9th March 2007, 12:35 AM   #5
FastEddy's Avatar
Somebody here has the catch phrase: Any op-amp is good as long as the implimentation is done right ... or words to that effect. I suppose you are right, the chip could be made to work in a specific, low power application ... probably not as an output amp except maybe for headphones ...
Old 9th March 2007, 03:04 AM   #6
BWRX is offline BWRX  United States
diyAudio Moderator Emeritus
Certainly any application that the low power Tripath amps are used in!
This chip is very comparable to the MP7720 except it's in a SO20 package with a couple more features and better thermal dissipation.
Brian
Old 9th March 2007, 12:52 PM   #7
Thanks for all replys but I still won't to know if there is anybody who has a PCB for this chip. Or someone who could draw it. I did my own pcb but it doesn't work
Greatings
Old 9th March 2007, 04:35 PM   #8
I would create a layout for you if I had time. Unfortunately I don't have much of that at the moment. What did you create the layout in? If you made it in Eagle send the files my way and I can take a look at them for you.
Brian
Old 9th March 2007, 04:51 PM   #9
Unfortenately I made it in PCBexpress and then out of anger I deleted it. Well I'm not in the rush with this amp so when you'll have some time please make one.
I'm very thankfull for your attention BWRX.
Greatings
Old 9th March 2007, 05:22 PM   #10
IVX's Avatar
mravlcax, try to post your PCB here as .png or .gif. BTW, i would build at this chip UcD like amp.
Best regards,
E1.
newbie with input tran. question and wiring question imo Solid State 0 18th January 2006 10:10 PM
Capacitor Question /question on cap TunaFish Tubes / Valves 14 12th January 2004 02:23 AM
PS question - tformer question actually breguetphile Chip Amps 2 30th May 2003 01:29 PM
old speaker question, bullet midrange question & link to speaker project wallijonn Multi-Way 10 5th November 2002 06:03 AM
Page generated in 0.10164 seconds (80.85% PHP - 19.15% MySQL) with 10 queries
