diyAudio
diyAudio (http://www.diyaudio.com/forums/)
-   Class D (http://www.diyaudio.com/forums/class-d/)
-   -   2,5v dc offset!! (http://www.diyaudio.com/forums/class-d/97482-2-5v-dc-offset.html)
nicoch58 4th March 2007 09:18 PM
2,5v dc offset!!
:( just finish the amp11 but in the two cannels I have the same dc offset ,whith trimmer I can conpensate a little 1,930.
visual inspection all perfect ,no bridge, component value ,solder joint.....suggestions ??
PS
my amp3 have 70mv ,the normal max is 100mv ,2,5v is too big....i hope is not the tripath chip,rework is hard....the strange is in all two cannel!!!!
manu
BWRX 4th March 2007 09:53 PM
Which chips does the amp11 use? You may want to try posting this on the 41hz forums as well. You will probably get more specific answers there.
nicoch58 4th March 2007 11:02 PM
HI Brian, TK2050 like AMP4 dual mono version
Copyright 1999-2017 diyAudio
