| Class D Switching Power Amplifiers and Power D/A conversion |
Need some advice on output inductor power requirements - probably current, actually.
Assume a 100Wrms system, so Pmax = 200W. Switching F = 500KHz. Output load > 4-Ohm. Imax is going to be SQRT(Pmax / R), or SQRT(50) = around 7A. Irms is something like 5A. Based on that, do I choose an inductor that can handle 7A? Even though audio has the crest factor thingy going on (8:1) and will likely never have 7A on a continuous basis. When do the cores fail? Is it when the max current is exceeded. I believe one data sheet described the max current at the point when the inductance dropped to 80% value (core is starting to saturate). Anybody seen the transformers from Panasonic that are meant specifically for class-D? Check out ETQA17B220. Digikey even has them for around a buck or 2. One more thing - how does the switching frequency affect the inductance, or any other paramete? The inductors I've looked at are spec'd at 10KHz. What happens at 500KHz? thanks gene |
#2 | ||||
diyAudio Moderator Emeritus
Brian |
#3 |
Conventional SMPS inductors are hardly useable at 500Khz. Also, conventional solid magnet wire is not very suitable for such high frequencies due to skin effect, and due to eddy currents when gapped ferrites are used.
I use to feel like the small child in The Emperor's New Clothes tale
#4 | |
Pmax is Power of P2P or ?? |
#5 | ||
![]() Prms = Irms *Vrms Ppk = Irms*sqrt(2) * Vrms*sqrt(2) Ppk = Irms * Vrms * 2 Ppk = 2 * Prms |
#6 |
Yeah, that one got me too a while back
![]() Prms = Irms *Vrms Ppk = Irms*sqrt(2) * Vrms*sqrt(2) Ppk = Irms * Vrms * 2 Ppk = 2 * Prms [/B][/QUOTE] i think u r still wrong ![]() take a look ![]() it seem Vrms=V_p2p/2.8285 ![]() do u think so? |
#7 | |
Are you confusing peak-to-peak with peak power (or peak voltage or peak current)? Check my first post, I wrote Ppk which meant peak power - not peak-to-peak. |
| Understanding DC power requirement for amplifier board | macpaulster | Digital Line Level | 11 | 4th January 2009 08:15 AM |
| Power supply requirement for Class D amp. | e_fortier | Class D | 2 | 29th December 2008 10:19 PM |
| Power supply requirement help | araven | Power Supplies | 1 | 8th August 2006 07:26 PM |
| Source for output air cor output inductor?? | sam9 | Solid State | 7 | 19th January 2004 02:25 AM |
| Minimum power requirement | Seville | Multi-Way | 3 | 3rd December 2001 01:15 PM |
| Page generated in 0.10896 seconds (78.10% PHP - 21.90% MySQL) with 11 queries |
