Go Back   Home > Forums > Amplifiers > Class D
Old 20th February 2007, 05:27 AM   #1
thefish is offline thefish  United States
Default My PWM schematic
I am building my first ever from scratch Class D amp (or any amp for that matter), I have designed the attached circuit to do my PWM let me know what you think. Note that the Op amps shown in the schematic are incorrect actually all 3 will be OPA134 amps. I know the frequency of the triangle generator is not very high but this will be primarily a bass amp (<500Hz) so I think it will be ok.
Old 20th February 2007, 05:28 AM   #2
Oops forgot to attach the schematic...
Old 20th February 2007, 06:03 PM   #3
While I am at it here is the second stage of the amp (complementary push pull with dead time to drive the FET’s)... looks like a lot of views but no comments...
Old 21st February 2007, 10:36 PM   #4
Default PWM Schematic
For the comparitor use a real comparitor like the LM319. Op-amps are louse comparitors. For your DC level shifter, do not use the audio source as a DC path to ground. Ground the part you use for an input and apply the audio to the mid point through a capacitor. The way you have it now will cost you 1/2 of the audio level. In addition the least amount of noise on your power supply will be coupled into the audio.
And many audio sources do not like to have DC current fed back into their outputs.
Finally, your modulator is the most basic and simplistic modulator around and has been used for years. It is know to sound bad for anything other than sub woofer use.
See some typical designs at www.schematicsforfree.mattsoft.net. In the section Audio/Cricuits/Power Amplifiers - Class-D.
Dan Fraser
Old 22nd February 2007, 01:45 AM   #5
Default Re: PWM Schematic
Well it seems I have a lot more work to do ...
The 5V supply comes from a simple 7805 regulator with a capacitor on its output. I have improved the input level shifter design already (as seen on the new schematic) with a 500K input resistance. I will take a look at this web page you have linked to... thanks for the input!
Old 22nd February 2007, 03:53 PM   #6
Default Input coupling
Apparently you have not yet realized that when you are using a single supply voltage, you must couple ground referenced audio into the circuit through a capacitor. In this case, a 10µF 25V or higher capacitor with the - side to the source and the + side to the 100 K resistor going to the inverting input of your op-amp will do.
Because this circuit, the way it is, with a ground referenced input will have a DC output operating point that is at some other odd voltage. Bias the non-inverting input of your input op-amp at 50% of your supply voltage and use a coupling capacitor on the input.
Otherwise, your DC operating point of the circuit is undefined. And many real world source devices, do not like having a DC current flowing back into their output, no matter how small it is.
Dan
Dan Fraser
Old 22nd February 2007, 06:09 PM   #7
Thanks, I understand what you are talking about now... ok I have improved that part of the circuit...
The goal of this project is to get something that works ok and safely though maybe not the best quality... after I get this to work I will start improving parts of the circuit to improve audio quality.
Old 22nd February 2007, 07:18 PM   #8
Default You're getting better
You are getting there. Your BIAS line needs to have a big capacitor, several hundred µFd to ground as it has to act as an AC ground.
The resistors R2 and R4 are too large for good S/N. The smaller these are, the less hiss you will get. 10K is pretty well the upper limit. 430K is just to big for optimum S/N.
The 339 is an OK comparitor but for better sound quality you need a more precise device like the 311 or 319. For the schmidt trigger in your ramp generator, U2, an op-amp works but is not ideal. Actually one of the best op-amps to use as a comparitor is the LM358 or LM324 as it does not exhibit as much latch up when operated virtually open loop. Good audio op-amps do not like to be comparitors.
Dan Fraser
Old 23rd February 2007, 01:33 PM   #9
Ouroboros's Avatar
It looks as if you're using the free Texas Instruments version of 'TINA' to simulate your circuit. You need a comparator with less than 100nsec response time, so I'd check the library to see what is in there.
Alternatively you can spend €50/$70 or so to buy the lowest-cost version of TINA itself and you can then pull in SPICE models from other manufacturers or construct comparators out of the basic elements (ideal comparators, ideal subtractors, ideal time delays etc that TINA provides.
Old 23rd February 2007, 02:38 PM   #10
zilog is offline zilog  Sweden
LTSpice from linear technology is free and really good. And you can pull in spice models from anywhere if you like to.
looking for a pre-amp schematic steamPunk Tubes / Valves 3 3rd August 2008 01:49 PM
DBX 500 schematic d3imlay Solid State 0 2nd August 2008 05:12 PM
F3 schematic kenev Pass Labs 2 24th January 2008 03:24 PM
Need Six-pac amp schematic Sarge Tubes / Valves 1 31st July 2004 08:30 PM
Page generated in 0.12677 seconds (72.52% PHP - 27.48% MySQL) with 11 queries
