Go Back   Home > Forums > Amplifiers > Class D
Old 16th February 2007, 05:20 PM   #1
FastEddy's Avatar
Default Of interest to Class-D amp scratch builders
I spotted this Dallas Semi. / Maxim ad in a trade journal and was wondering if anyone has actually tried using Ferrite Beads or Lugs on the outputs instead of large coils or inductors ...?
Note the use on Page 15 of this pdf file: http://www.maxim-ic.com/cgi-bin/dg?d...PANEL_DISPLAYS
Old 17th February 2007, 07:12 AM   #2
mzzj is offline mzzj  Finland
Default Re: Of interest to Class-D amp scratch builders
Originally posted by FastEddy
I Ferrite Beads or Lugs on the outputs instead of large coils or inductors ...?
Does'nt work with "normal" class-d amplifiers, inductance values required are several decades bigger. (and thus size) Maxim's solution drives loudspeaker with raw pwm signal and ferrite beads are there only to filter out RF-trash(something like 10MHz and upwards)
Old 18th February 2007, 02:07 AM   #3
FastEddy's Avatar
" ... I sorta stopped because I began wondering if it was worth my effort and expense, when for not much money I could buy a better outboard dac, and use that. ..."
Thought it might be something like that = a simpler solution that may or may not be better. I also was aware that this would apply to Dallas / Maxim ONLY Class D amps ... so far.
Any thoughts on improvements to this scenario ... or is it the wrong road to take??
"When you get to a fork in the road, take it!" - Yoga Berra
Old 18th February 2007, 05:42 PM   #4
Pano is offline Pano  United States
Pano's Avatar
This has been discussed some before, scattered across several threads.
I think this could be done with many H-Bridge class-d, as long as the speaker leads are very short - or maybe shielded.
The question (apart from RFI) is what will the driver load do to the switching transistors? It something I been wanting to test with horn compression drivers.
Take the Speaker Voltage Test!
My first Class D from scratch... thefish Class D 22 13th July 2008 08:13 PM
Dynaco from scratch TubeMack Tubes / Valves 25 2nd September 2006 06:20 PM
Final Scratch d-tripod Digital Source 0 17th February 2004 09:19 PM
Class A mosfet amp builders in Queensland Australia? gregjpeters Pass Labs 3 6th November 2002 09:46 PM
How to design an amp from scratch... Bakmeel Solid State 1 26th March 2002 01:10 AM
Page generated in 0.07213 seconds (83.24% PHP - 16.76% MySQL) with 10 queries
