| Class D Switching Power Amplifiers and Power D/A conversion |
Searched, but could not really find an answer...
Got this Outlaw Audio 7*200W final amp from the USA, weighing over 50kg and working from 115VAC. After a lot of brain activity here I concluded there is no easy way to convert this to our 230VAC, as the two gigantic toroidals aren't identical, so merely wiring the primaries will not work. Besides, the weight makes the amp difficult to handle... However, the (linear) 7 boards are really very nicely made and fully balanced, too nice really to leave gathering dust... Which made me think, are there any small switching supplies around that output approximately 28-0-28VAC, or do they all output DC only? I already asked Coldamp, and as usual got a very friendly and helpful answer already, but their supplies, beautiful as they are, do not supply AC, but could be converted to 40VDC*2, which I will probably attempt should all else fail. Suppose I would need 2 or 3 smps supplies of 400W. Thanks for thinking with me! Barend (Holland)
#2 |
Did it Himself
Are you sure the primaries are not 2x 110v currently wired in parallel, which can be wired in series?
www.readresearch.co.uk my website for UK diy audio people - designs, PCBs, kits and more |
#3 |
Yes they were, and in my innocence I tried wiring them in series, but that gave me 75V on one on 130V on the other primary, because one toroid supplied 4 amps and the other seven...
Adding a forcing toroidal 0-115-230 across the three points 0-115. 115-0 improved this 75-130 to 108-120 but added even more more weight... So I see only the option of working with a switching supply... |
#4 |
How about getting a 1.5KVA 220Vac to 110Vac transformer to supply the amp with? Or get two toroids with the corresponding voltages, they're much cheaper than getting SMPS's.
Deep down inside. |
#5 |
No, because a) I don't want a humming beast of a stepup transformer in my living room and b) I don''t want the heavy weight...
#6 | ||
Did it Himself
| Some experiments with switching power supplies | Bootstrapper | Power Supplies | 17 | 22nd June 2008 11:03 AM |
| Parallel-ing Switching Power Supplies | JohnT_diy | Power Supplies | 11 | 7th July 2007 04:00 PM |
| Power supplies switching on consecutively | barendh | Class D | 2 | 20th February 2007 12:43 PM |
| Parallel a dual power supply or two power supplies? | Thunau | Power Supplies | 12 | 16th February 2007 04:21 AM |
| Multiple Switching power supplies Problem? | magudaman | Power Supplies | 1 | 23rd February 2005 02:51 AM |
| Page generated in 0.08742 seconds (76.08% PHP - 23.92% MySQL) with 10 queries |
