Really Nutty Class D (RNCD)
Old 6th February 2007, 09:41 AM   #1
Duo is offline Duo  Canada
Duo's Avatar
Send a message via ICQ to Duo
Default Really Nutty Class D (RNCD)
Here I present something to make all of the class D amplifier people turn green.
Those engineer types will see what's going on here. If you don't get how this thing works, ask and I'll come back with a reply. It's pretty simple though.
Old 6th February 2007, 05:38 PM   #2
IVX is offline IVX  Russian Federation
IVX's Avatar
Wow, one more NCD?
Best regards,
E1.
Old 6th February 2007, 08:11 PM   #3
Duo's Avatar
I can't believe I indicated a P-channel in the diagram.
For the record, it is N-channel.
Old 6th February 2007, 09:37 PM   #4
darkfenriz is offline darkfenriz  Poland
darkfenriz's Avatar
what's the diode for?
Old 6th February 2007, 10:03 PM   #5
Duo's Avatar
The diode rectifies the output of the switching driver. If it was not there, the device would be trying to switch 10V at 60KHz into the cap and load.... Not good. (This is a switching amplifier, not linear.)
Old 6th February 2007, 10:07 PM   #6
darkfenriz's Avatar
So if I understand correctly you've built a VCO and output diode works as a FM-discriminator, is it right?
Old 6th February 2007, 10:10 PM   #7
Duo's Avatar
No.
This works on duty cycle.
The average amount of power in the inductor is controlled by pulse width, and to some extent, frequency.
Old 6th February 2007, 10:37 PM   #8
darkfenriz's Avatar
OK, I think I got it...
You called it classD/A because it is both PWM and ineffifient?
Old 7th February 2007, 01:12 AM   #9
Duo's Avatar
Well, it's probably about twice as efficient as a typical class A of the same topology.
What you see here is a class D stage acting as the upper transistor of the class A stage.
The resistor acts as the class A stage's load in order to pull down and do the other half of the wave.
Old 7th February 2007, 01:48 PM   #10
theAnonymous1 is offline theAnonymous1  United States
theAnonymous1's Avatar
I have 3 questions......
1) Can I mod this with better input caps?
2) What kind of speaker cable should I use?
3) Can you recommend me a power supply?
Really Nutty Class D (RNCD)Hide this!Advertise here!
New class A biasing (with non-switching class AB overflow) Steven Solid State 34 24th March 2007 07:40 PM
How about a round-up of Class A kit power amps, or collectable vintage class A? Brisso57 Solid State 4 14th February 2007 11:30 AM
Nutty idea? thayerg Full Range 2 6th January 2005 09:04 AM
Copyright ©1999-2017 diyAudio
