paradigm atom and t-amps
Old 5th January 2007, 03:39 AM   #1
jesserparker is offline jesserparker  United States
Default paradigm atom and t-amps
so i am buying a pair of paradigm atom speakers, and am planning on mating them with a t-amp. i don't believe that most of the lower powered amps (original si, ta2020 based, etc.) will be enough with the atom's 89db efficiency.
at the moment my best plan is for the 41hz amp5, which looks likea good match, but i was wondering if anybody out there had any other particular suggestions for this pairing. thanks
Old 5th January 2007, 03:45 AM   #2
john65b is offline john65b  United States
john65b's Avatar
I beleive the TA2020 should be fine...Don't know if you need ear-bleeding volumes, or have a big room, but the TA2020 would be perfect for smaller speaker like the Atoms (great speakers BTW).
AMP5 is 60w 8 ohm/100w4 4ohm (I think)...will also work fine, but TA2020 a better match
Old 5th January 2007, 05:03 PM   #3
i believe that the ta2020 based amps only go up to about 10-15 watts before distorting wildly, and the paradigm suggests at least 15 watts minimum, up to 60.
Old 5th January 2007, 06:20 PM   #4
Pano is offline Pano  United States
Pano's Avatar
You can "get by" with the TA2020, but you'll be happier with a more powerfull amp on those speakers.
You really need sensitivity in the mid 90s or better to get the best results with the small chips. Same of for SET amps.
Take the Speaker Voltage Test!
planet10 needs your help: Let's help Ruth and Dave
Old 5th January 2007, 09:22 PM   #5
that's what i thought. i do believer the amp5 should be sufficient for my purposes. . . unless, of course, anyone out there has any other suggestions. . . ?
Old 20th January 2007, 10:24 AM   #6
abiedoodles is offline abiedoodles  Bahrain
abiedoodles's Avatar
i have the amp6 and a infinity primus 150 88db bookshelf and its sufficient in my 10m x 8m room it can go loud enough.. but sometimes im looking for the bigger amp like amp5, i want more drive and bass coz mostly im listening to rock music.
paradigm atom and t-ampsHide this!Advertise here!
Paging SRETEN..off topic, I want an Ariel Atom please! grantnsw The Lounge 6 7th August 2008 07:19 PM
Paradigm 9s? meistah Multi-Way 7 20th October 2007 01:14 PM
Atom sized transistor... gmphadte Solid State 1 21st August 2007 05:19 PM
Any DIY project similar in sound to Paradigm Atom? manxam Multi-Way 6 22nd March 2007 09:39 PM
Paradigm Titan, Paradigm Phantom v1, a lot of help needed duraznov Multi-Way 3 25th August 2006 03:36 PM
Copyright ©1999-2017 diyAudio
