| Class D Switching Power Amplifiers and Power D/A conversion |
I found a circuit of trimming the output offset voltage of TA2024C on p.11 of the data sheet of TA2024C. It involves the adding of one 1M Ohm resistor, one 10KOhm potentiometer and one 0.1uF capacitor for each channel.
I would like to know whether this circuit can be applied to TA2020 of AMP6. Thanks. |
#2 |
Yes it can and it works well.
The Trends TA-10 also uses it, as well as some of the amps I built.
Take the Speaker Voltage Test! |
#3 |
Dear Michael,
Thanks for your quick reply. |
| High DC offset voltage at preamp output | mmerig | Solid State | 18 | 23rd May 2008 07:44 AM |
| 'Trimming' phono-pre's output with pot/attenuator | Aleksunder | Solid State | 12 | 1st September 2006 04:47 PM |
| output inductor in ta2020 | garbage | Class D | 8 | 9th September 2005 01:20 AM |
| Output buffer offset voltage | borges | Analogue Source | 0 | 24th August 2004 12:03 PM |
| How much output offset voltage is too much? | tubetvr | Solid State | 14 | 1st July 2004 10:47 PM |
| Page generated in 0.06560 seconds (81.14% PHP - 18.86% MySQL) with 10 queries |
