Hello everyone,
i want to build my new Amp9 from 41Hz with a 150W SMPS, i recently found a relatively cheap one from the company Mean Well.
Here is a link to the preferred types:
http://www.proconnecting.de/media/products/0720867001161458518.pdf
http://www.proconnecting.de/media/products/0534032001160266686.pdf
Has anybody tried these, especially with class-d amps?
Thanks a lot!
Nils
Thanks a lot!
Nils
For the price of that you can probably buy a SPS30 or even SPS80 from coldamp, that is specifically designed for audio and tested (only the SPS80) by a lot of people in the forum, including me, with excellent results:
http://www.coldamp.com/opencms/opencms/coldamp/en/productos/sps80/index.html?idioma=
We can make smaller voltage versions of SPS30, that is to be launched this week. The standard version can be adjusted in factory from +/-40V to +/-60V, but if a reasonable number of supplies are demanded, we can make a custom version with +/-24V output (or +/-12V output if you need only +24V)
Hope this helps.
Best regards,
Sergio
Hope this helps.
Best regards,
Sergio
Pierre said:For the price of that you can probably buy a SPS30 or even SPS80 from coldamp, that is specifically designed for audio and tested (only the SPS80) by a lot of people in the forum, including me, with excellent results:
No doubt Coldamp provides excellent results. But for what concerns the price, I'm not sure you will get the SPS30 for 60 €.
This 150W SMPS costs less than 30€ !: say you buy 2 of them for +/-24V et voila... Do not misunderstand my point: I don't know if one can compare one pair of S-150S with SPS30 (f.i, you will not have 5V or 12V out of the box) but if this is half the price, it might be worth to try.
Christian
