Go Back   Home > Forums > Amplifiers > Class D
Old 20th December 2006, 01:39 PM   #1
zilog is offline zilog  Sweden
Default ringing of mosfets in UcD simulation
I am trying to choose initial values for my UcD from a LTSpice simulation, but I run into problems with ringings of the gate waveforms aswell as the associated rinings in switching voltage waveforms and current waveforms. I have attached two images below, and I hope to get some feedback regarding the trustworthyness of these LTSpice simulations. I have used Fairchilds "complete" model of FDP3682 which takes into account the body diode, wire inductance etc.
Old 20th December 2006, 01:40 PM   #2
Waveforms
Old 21st December 2006, 12:19 AM   #3
Gorilla is offline Gorilla  United Kingdom
Do the images look badly shrunk when you download them?
Old 21st December 2006, 01:51 AM   #4
BWRX is offline BWRX  United States
diyAudio Moderator Emeritus
Yes, they do look very bad (illegible really).
Perhaps you could try putting a small value resistor in series with each mosfet gate. This will prevent them from interacting as much, which may be part of the problem.
Brian
Old 21st December 2006, 09:44 AM   #5
I already use gate resistors, the ringing occurs in spice no matter what value I give these, therefore I suspect that spice sucks.
The images look like **** from resizing, I have absolutely no clue of how ot resize with anti-aliasing in Windows as I am a complete newbie to microsoft products.
Old 21st December 2006, 10:42 AM   #6
Really? They don't even show up in the attached picture. I meant directly in series with each gate since you're using mosfets in parallel.
Are you using MS paint or something? Download the gimp. It's like photoshop but free. You can resize images nicely with that app. I'm not a 'native' windows user either but am forced to do so at work...
Brian
Old 21st December 2006, 10:46 AM   #7
No need to go individual when parallelling a BSN254A and a FDP3682, orders of magnitude in difference between them. I guess the pictu´res are too bad to see the ringing if you dont know where to look.
Old 21st December 2006, 11:14 AM   #8
The ringing is easily visible on your graph, I just can't read any of the text on the schematic.
Why do you have BS2N54A's in parallel with FDP3682's? If you disconnect the BS2N54A's is the ringing still there?
What is that dode and cap you have coming off the gates of the output fets?
Sometimes when you resize an image to a fraction of it's size that isn't 1/2, 1/4, 1/8, etc. the program can really mess it up.
Brian
Old 21st December 2006, 11:22 AM   #9
I use the BSN254 to measure the output current by current sharing, so I include part of that circuit in the simulation to account for its drive requirements.
The ringing is still there independent of the BSN254.
Old 21st December 2006, 02:19 PM   #10
alfsch is offline alfsch  Germany
with inductance + caps (even if only inside the mosfet) you make some nice resonating loops....so you always get some ringing.
this happens in real world also, so whats your problem??
btw: i think, spice (or swcad) always shows correct results, as long as the models u use are perfect. (and whats perfect in this world...)
Ringing Mosfets Rog Solid State 1 2nd March 2004 09:21 PM
Overshooting, ringing and blowing up mosfets if you build stuff based on irresponsible advice Fred Dieckmann Solid State 100 30th July 2003 10:22 PM
Page generated in 0.09990 seconds (78.27% PHP - 21.73% MySQL) with 11 queries
