| Class D Switching Power Amplifiers and Power D/A conversion |
Hello,
I was wondering if I could add extra PSU capacitance for the little T-amp like shown on the attached scheme? Would this approach be better than the usual cap over + and - in any way? |
#2 |
The t-amp uses only a positive voltage and ground. You have drawn a positive-ground-negative supply. This would only apply to the larger tripath chips. A standard (or modded) sonic impact (or similar) would not benefit from this proposed psu.
best regards, psz. |
#3 |
Adding big caps will help the T-Amp. You get a more stable power supply rail
As noted in the post above, you have shown a split rail PSU. The small T-Amps use a single rail. Otherwise, this will help. So will getting a large, good cap near the chip.
Take the Speaker Voltage Test! |
#4 |
Thanks for clearing that out for me.
| Wiring HT2 MTM | ZoZat | Multi-Way | 4 | 15th May 2009 09:17 PM |
| Focusing on wiring cable for gainclone!!!Share ur experience in wiring cable.... | thomgun_lc | Chip Amps | 38 | 31st August 2005 02:46 PM |
| I'm wiring my 4 channel 8 parallel LM4780 boards... check my wiring :) | Audiophilenoob | Chip Amps | 9 | 16th August 2005 04:37 AM |
| Page generated in 0.07194 seconds (70.86% PHP - 29.14% MySQL) with 11 queries |
