Go Back   Home > Forums > Amplifiers > Class D
Old 16th December 2006, 12:54 AM   #1
Send a message via AIM to Spasticteapot
Default Cheap SMPS PSUs for class D modules.
I figure that links to cheap PSUs would be very handy, so here's what I've found:
1. 100w 24v SMPS power supply - $40.
http://www.web-tronics.com/1024siouposu.html
2. 3.3, 7, 5, and 12v power supply. 4A on 12v line. - $10.
http://www.weirdstuff.com/cgi-bin/item/22133
Now, if someone could find a cheap 30-32v PSU...
Old 16th December 2006, 01:24 AM   #2
Purchased this a while back for a gainclone. I haven't built the gainclone but the price is right and the seller is very helpful. Seller provides parts for a mod that reduces the voltage to 38v.
http://cgi.ebay.com/Switching-Power-...QQcmdZViewItem
Old 16th December 2006, 07:45 AM   #3
Fin is offline Fin
Fin's Avatar
Would this be a suitable supply for an EB-TA0103
EB-TA0103
Fin
Old 16th December 2006, 12:14 PM   #4
It has a 5V output and the +- rails are within the Tripath required range. There is a link in the Ebay listing that provides additional documentation that might help you. I'm new to diy amps (couple 41hz amp3 and SI mod). I'm going to try this with a LM3886 P2P. I did the mod and it gives me 38v. High for the LM3886 but below the max voltage. For my minimal investment I'm willing to plug it in and see what happens. You might want to be more cautious.
Old 16th December 2006, 12:29 PM   #5
Fin is offline Fin
Fin's Avatar
Hi bcrescen
The TA0103 can use +/-35 to +/-54V....so these are right in the middle of that range...so I assume that is OK.
My main concern was the amount of power that these SMPS can supply. Most others building amps with TA0103, TA0104 and TA3020 seem to be using large torroidal transformers of around 600VA to 1000VA. The Tripath datasheet mentions something about requiring 7A at +/-45V....but that seems to be at full power - which I don't intend to use.
Anyway - I decided to buy two of those SMPS and will try them in parallel. That should give me +43V @ 4A and -43V @ 4A. Hopefully it will be good enough for typical use at reasonable levels.
BTW - thanks for the link to the SMPS.
Fin
Old 17th December 2006, 04:15 AM   #6
vectorplane's Avatar
Default finding the eBay SMPS
The link provided points to an expired listing.
Fortunately ebay keeps the records of old listings around for a while after the end of auctions, so I could re-trace that SMPS with a search for items by same seller.
Rather than searching by item nr, which changes all the time, you may be better off searching by keywords in the title, which doesn't seem to change:
"Switching Power Supply Dual +/-43V 2A >Audio power amp",
or by seller id "stadholder"
vectorplane
Old 18th December 2006, 12:36 AM   #7
Here's an 8-amp 24-volt power supply for $35.
http://www.herbach.com/Merchant2/mer...egory_Code=PWS
And here's a 6-amp +/-12v power supply for $15.
Old 18th December 2006, 12:41 AM   #8
Old 18th December 2006, 02:18 AM   #9
H&R has some interesting stuff, but it's expensive for surplus.
Those supplies aren't very good value considering the low output voltages.
When you go to class D, you don't do it for 20W output.
So you need hefty voltages.
Old 18th December 2006, 03:05 AM   #10
+/- 12v is equivalent to 24v at six amps - not huge, but not too bad, either.
Using 2 amp modules from 1 SMPS MikeHunt79 Car Audio 2 31st March 2008 08:54 PM
Sale: Hypex UcD400AD Class D modules and Coldamp SPS80HV SMPS proengin Swap Meet 4 16th July 2007 02:00 AM
A cheap 12v SMPS for class D Foxx510 Class D 0 22nd December 2006 07:55 AM
Hacking SMPS PSUs? Spasticteapot Power Supplies 4 20th November 2006 03:40 PM
SMPS modules Nuuk Swap Meet 0 2nd June 2005 09:01 AM
Page generated in 0.17604 seconds (60.77% PHP - 39.23% MySQL) with 10 queries
