| Class D Switching Power Amplifiers and Power D/A conversion |
Hi folks.
I read the Trends-Audio T-Amp specs yesterday. It says that biasing the output DC to 0V, as it is possible with their model, brings a. cleaner sound b. smaller switch-on pop Does anybody have an idea how such a biasing circuit could look like? Cheers Klaus |
#2 |
The circuit is here:
http://www.tripath.com/downloads/TA2024C.pdf See page 11. You can see it in the Trends amp photo below. Look for the trim pots labled Rt.
Take the Speaker Voltage Test! |
#4 | |
I am going to add the adjustment circuit to an AMP3 sometime soon. I already made the board, just have to attach it. |
#6 | |
#7 | |
diyAudio Moderator Emeritus
I guess no one uses the search function anymore, eh? http://www.diyaudio.com/forums/showt...ht=#post890408 http://www.diyaudio.com/forums/showt...ht=#post915158 http://www.diyaudio.com/forums/showt...ht=#post906760
Brian |
#8 | |
To me it's still not clear if the biasing improved the sound! |
#9 |
Why would it improve the sound? All it does is remove the DC from the outputs. You can't hear DC...
A low DC offset is important for drivers with limited xmax because the more DC offset there is on the output the lower the usable excursion you have from your drivers. Any DC offset also causes a quiescent current to flow through the driver's voice coil. The larger the offset the larger the current and the more heat the amplifier's output stage and the driver's voice coil has to dissipate (even though the amount is really very small and is usually considered negligible).
Brian |
#10 | |
Are 100mV or whatever offset, respectively the corresponding lower driver excursion, audible. Or is the main thing to balance both channels offset so the drivers start at the same point. Or should I better take it that way , as you nicely outlined: Since DC is not audible. We shouldn't care about it!
| Output Tube biasing for Toroidal Output Transformer | gingertube | Tubes / Valves | 7 | 17th April 2005 04:40 PM |
| output transistor biasing question? | crippledchicken | Solid State | 7 | 16th April 2004 12:48 AM |
| Automatic biasing of output stage | Circlotron | Solid State | 8 | 14th June 2002 01:13 PM |
| Biasing output stage FETs | PeteMcK | Solid State | 7 | 7th February 2002 09:37 PM |
| Page generated in 0.11231 seconds (80.30% PHP - 19.70% MySQL) with 11 queries |
