| Class D Switching Power Amplifiers and Power D/A conversion |
Basically I am a fan of 3D-P2P constructions. But my handmade schematics and handmade routing plans were somehow annoying. And – frankly speaking- a relict of the last century. OK, even if learning is hard in my age... No way around starting my first babysteps in CAD. I decided to use the cost free Eagle Light. And my current class D project was exactly right for that, so I went for a 2 layer PCB with ground plane structure.
Schematic first. It is an self resonant hysteresis design. A fast comparator (LM160) with inverting/noninverting outputs to generate also the signals for a full bridge. Each halfbridge is using a IRS 20954 driver and two IRFB52N15D MOSFETs. The missing connection in the schematic between upper source and lower drain will be a wire, because I need to do current measurements in this wire for optimized dead time adjustment. Each PCB is just one half bridge with comparator, but without output filter. For a full bridge the comparator is only needed on one PCB and delivering the signals for both half bridges. So far my theoretical plans... Reality will show.... |
#2 |
Today I received the PCB samples and was quite pleased about the quality.
I got samples with 35 micrometers copper thickness and with 70 micrometers. Somehow I feel more comfortable with thicker copper especially for my 1kW full bridge, with max. currents around 50A... Component side: |
#3 |
Ground side:
#4 |
Uhm, this is a promising project... Go on with it. I wish I could have double-sided hole-plated PCBs with solder mask and silkscreen as yours delivered quick and cheap here
Currently I have to print, expose, reveal, etch and drill my own double sided boards (no plating BTW: My new 2500W low-frequency class D amplifier powered with 416V directly from the output of a PFC is working and almost ready. I may post some pictures soon for you to see. I have been really scared sometimes during the development because the capacitor bank at the output of the PFC stores around 200 joules
I use to feel like the small child in The Emperor's New Clothes tale
#5 |
Eva, we want to see this monster
.Why do you have to manufacture the boards on your own? If you have Gerber files, I can help you. But this also shouldn't be a problem in Madrid. What does "PFC" stand for? Marek |
#6 | |
/U. |
#7 | |
Oh, yes... you designed your inrush current limiter for obvious reasons....and just to mention... don't let your screw driver drop into the running circuit.... or fry your necklace... it's a good habit to be slightly scared, when handling such energies. My PCB... fast? ...delivery time is 2 weeks. And it is not cheap at all, even in China. But living in China is cheap, so I can spend more money on my hobby. And honestly I start to enjoy professional PCBs, even if expensive. It is fantastic: You play around at the computer with some CAD software, make some schematic, some virtual pictures..., then let the machine generate some mysterious data files and send them out (OK, I first had a look to them with a gerber viewer). Like from wizzard's hand some weeks later you get the real thing!!! And it is really exactly what you wanted to have! I love it! Aren't there PCB companies in Spain? Or is it mostly a matter of money? How much would it be ? |
#8 |
ChocoHolic,
How much did you pay for your board? I assume it is smaller than 8x10cm. I may ask my company how much would they charge for such a board. They have standard term of 5 days but there is an express option too (more expensive). Marek |
#10 |
With my company, if you'd order 1 board (1dcm2), the price would be < 24Euro. But if you order >= 10 boards, the price would be about 10 Euro.
Marek |
| help a rookie | Xplorer | Car Audio | 1 | 22nd June 2004 11:11 AM |
| Hello from a rookie! | lynkage | Introductions | 1 | 24th February 2004 08:44 PM |
| Rookie saying hi! | verbalkint | Introductions | 0 | 11th February 2002 06:32 AM |
| Page generated in 0.12451 seconds (83.72% PHP - 16.28% MySQL) with 11 queries |
