| Class D Switching Power Amplifiers and Power D/A conversion |
What am I doing wrong here? I took the center of the RCA to the attenuator and then on the other lug went to the positive of the Charlize. Am I missing something?? Does anyone have pics of a properly wired one? I miss Charlize and am considering plugging her back in with a preamp in front.. Thanks - Trent |
#2 |
Hi Trent,
We're going to need more details than that. What about grounding? What problems are you having? A wiring diagram? etc.
Take the Speaker Voltage Test! |
#3 |
Somebody else had a similar question not long ago. I know the search is a you-know-what. But try. It's worth it.
#4 |
I've searched... I wish I could have found something. I'll try again. Okay, I'm running from the center lead to the prong on one side of the attenuator. Right next to that is another prong that I'm running out of. The grounds are direct to the Charlize. I can't think of another way to do this without three prongs??? Sorry to be such a newb but the thing plays at full volume all the time... |
#5 |
Have a look at this pic of the attenuator and it needs a ground connected to it to work properly.
In from the RCA's, out to Charlize and the ground is er, the ground from the RCA.
No longer DIY active |
#6 |
Thanks for posting the photo, Rabbitz. That should help Fowler plenty.
I think I bought the exact same attenutator out of Oz. Great deal, it was. Very well made.
#7 |
Where abouts did you get that attentuator from Panomaniac? Thru ebay or a shop?
#8 | |
try this URL ... http://www.diyfidelity.com.au/produc...products_id=32 Page down to step6. 6. Grounding Use the remainder of the tinned copper wire and put it through to the unused position (24th). and bend it so that it can reach the ground of the switch (See picture). Hope this helps KL
KL. |
#9 |
Thanks for that link KL, you answered my question too
#10 |
these steppers have 23 pos. don't forget that. You can never go 1:1. There is some minor att. present on the last pos.
Kind regards, Bert |
| Fidelity Research FR-101 | Stuey | Analogue Source | 2 | 1st June 2007 09:59 AM |
| Focusing on wiring cable for gainclone!!!Share ur experience in wiring cable.... | thomgun_lc | Chip Amps | 38 | 31st August 2005 02:46 PM |
| I'm wiring my 4 channel 8 parallel LM4780 boards... check my wiring :) | Audiophilenoob | Chip Amps | 9 | 16th August 2005 04:37 AM |
| What is hi fidelity? | destroyer X | Solid State | 60 | 5th June 2004 01:39 AM |
| Wiring a DACT CT2-10k-4 Audio attenuator | raincheck | Pass Labs | 3 | 9th March 2004 09:33 PM |
| Page generated in 0.10498 seconds (75.87% PHP - 24.13% MySQL) with 11 queries |
