Class D Design Issues
Old 28th July 2008, 02:20 PM   #31
fatihcol is offline fatihcol  Turkey
Send a message via MSN to fatihcol
Default DWM3640NHV_V30
hi;
in board u1,u2 = ir21844s
u3 =tl072
u4 =lm211
d1,d3=12volt zener
sorry i'm little english
good luck
Old 28th July 2008, 02:26 PM   #32
Ouroboros is offline Ouroboros  England
Ouroboros's Avatar
Default Re: UcD Amp Design paper
Originally posted by arif__anwar
would anyone be able to suggest a UcD design paper with a basic design and calculations so i can figure out how the thing works??..any help would be great
The best place to start is Bruno's original paper to the AES.
A copy is available online at:
www.ciaudio.com/ucd_aes.pdf
Old 28th July 2008, 09:07 PM   #33
exorcista is offline exorcista  Italy
"DWM3640NHV_V30"
replaced the other problem I ic overheat njm4556 too!
Old 29th July 2008, 09:05 AM   #34
Default 3s-tec amp
Originally posted by exorcista
"DWM3640NHV_V30"
njm4556 (u3) is hot because triangle jenerator.
Old 29th July 2008, 11:22 AM   #35
njm4556 is the pre dell'RCA is too overheat even after 10 seconds from what may depend
Old 1st August 2008, 10:00 AM   #36
i' m repair today. g-z 5000spl same your amp
amp's blow ir21844s an 360lc
Old 18th August 2008, 12:46 PM   #37
mhouston is offline mhouston  Australia
mhouston's Avatar
Default Class D amps - chips/modules
Is there a single Class D chip or module I can purchase, commercially, to make a complete amp from?
If so, from a musical point of view, what is the best chip or module?
Old 26th August 2008, 11:21 PM   #38
Jaimo is offline Jaimo  Canada
Default Tripath Chips
check out 41Hz.com
I can't comment on the quality but I plan to purchase a kit as soon as I figure out what suits my needs best.
Cheers!
Old 27th August 2008, 04:43 AM   #39
mhouston's Avatar
Default Re: Tripath Chips
Originally posted by Jaimo
check out 41Hz.com
Cheers!
I thought the Tripath was Class T?
Old 24th September 2008, 12:57 AM   #40
Pashley is offline Pashley  Canada
Originally posted by Groman
Do you know any ebook or web page of class D amplifier for beginners?
There's one at http://sound.westhost.com/articles/pwm.htm. It was written by someone from Coldamp, a vendor of class-D amp modules.
For another module vendor's take, go to http://www.hypex.nl/ and click on "technology".
Class D Design IssuesHide this!Advertise here!
Forum for issues related to the design of Class D amplifiers sovadk Class D 57 13th December 2006 06:45 AM
Copyright ©1999-2017 diyAudio
