Class D Design Issues - Page 10 - diyAudio
Go Back   Home > Forums > Amplifiers > Class D
Old 21st January 2015, 08:53 PM   #91
Dimonis is offline Dimonis  Russian Federation
Dimonis's Avatar
Originally Posted by valtra103 View Post
So in my 2ohm load case i shouldn't use 10uH ?
Can you measure the inductance of your tweeter ?
It'll be more easy to calculate the value of the inductor you need.
Old 22nd January 2015, 08:04 AM   #92
If i could measure inductance, i probably would have everything figured out. I dont have tools forr that.
Old 22nd January 2015, 10:23 AM   #93
doctormord's Avatar
If it sounds dull, you'll need less inductance.
Old 22nd January 2015, 10:59 AM   #94
So if inductance too big, then it will lack highs i believe. Thanks for help.
Old 22nd January 2015, 02:06 PM   #95
doctormord's Avatar
Yes, thats actually all. 22uH is a good rule of thumb, which works most. (Its just for compensate the HF-current)
You'll defo hear when it is to much of comepensation.
Old 7th September 2015, 11:33 AM   #96
Chov1ch is offline Chov1ch  Croatia
Hello, I ordered this amp but i hear that when you turn it on it works on 70% volume and with SMD Buttons you can volume up or lower.. so i want make when you turn on amp its automatic on max volume.. how its possible to make?
Screenshot by Lightshot
Old 9th September 2015, 12:46 PM   #97
doctormord's Avatar
You'll need to change the corresponding PSKeys in the CSR BT chip. Not possible without a programmer for there modules and the Toolkit provided by CSR.
Have you checked if increasing the gain via the 2 dip-switches is already enough "ompf" for your needs?
Old 8th October 2015, 08:59 PM   #98
Default Mini amp repair.. wrong parts?
Hey guys, still pretty new to all this.
So, I accidentally pulled the shaft out of one of my pots while trying to remove the knobs. I replaced a B100k with a B100k on the balance knob. Now it acts as another volume knob. All of them read B100k, so I don't understand why it's not doing the same thing it did before.. any ideas?
This picture is of a new one that I ordered with it's original pots. The one with the green sticker is the balance. What is different about this pot so I can repair the other one with the right part?
Thanks for any insight!
sorry it's sideways
Old 9th October 2015, 10:55 AM   #99
Sorry, I forgot to mention. The amp is the Kinter MA-180 and there are four knobs and a power switch.. volume, bass, treble, and balance.
sorry it's sideways
Old 14th May 2017, 09:44 AM   #100
JonasKarud's Avatar
I've always wondered why my Behringer NU3000DSP class D amp sounds so flat in the treble, so I decided to measure it acoustically (noise) connected to my ribbon speakers.
I normally use it as a bass amp, where it's doing a great job.
As you can see, on the red line, there's a whole lot of noise in the treble and very poor phase behaviour. Its the same on both channels, and the amp is setup in
straight mode without the DSP in operation.
For comparison, the blue graph is from a Nad M3.
Can the problem be due to a much to low modulator frequency?
Reality is just a word....
Forum for issues related to the design of Class D amplifiers sovadk Class D 57 13th December 2006 06:45 AM
Copyright ©1999-2017 diyAudio
