| Class D Switching Power Amplifiers and Power D/A conversion |
hey,
i have an AMP32-PS on the way and i was thinking to look for a power supply while i wait for it as shipping to israel could take around two weeks. i read that people like SMPS for class-D amps and i guess if it's good for most people it will do just fine powering the AMP32-PS which i'm building for a friend to power the speakers that connect to his PC. I admit not knowing too much about SMPS past the basic operating functions, so is there anything special I should look for other than the right ratings? any makers or specific models that are better for some reason? and do i have to use any other regulation or filtering or hooking them up to the amp is good enough? |
#2 |
1. If you are happy to dabble inside his PC - you could its 12V supply.
2. If you want something separate and external - you can use something like a laptop supply. You can get a universal one that lets you select the voltage output and could be handy for other uses too. Some laptop supplies like Toshiba and Sony are set at 15V and 19V respectively. You could then add extra regulation to bring this down to the required level. 3. You could get an uncased/open SMPS like the one NUUK sells - and build it into the case with the amp.
Regards Fin |
#3 |
can you please post a link to NUUK? thanks.
#4 |
found it, they also sell on ebay... not very cheap though. what about using them cheap notebook power supplies? i was thinking about getting one with a 12V output or one with 15V and simply use a regulator. would that work fine without any additional filtering?
#5 |
There are countless supplies on ebay that will work. I've had good results with the SMPS LCD monitor type.
Here are just a few that will work. These are all 14v regulated. http://cgi.ebay.com/AC-Adapter-for-D...QQcmdZViewItem http://cgi.ebay.com/New-Compaq-AC-Ad...QQcmdZViewItem http://cgi.ebay.com/DELL-1701FP-1702...QQcmdZViewItem http://cgi.ebay.com/14V-AC-power-ada...QQcmdZViewItem http://cgi.ebay.com/Dell-Monitor-Pow...QQcmdZViewItem |
#6 |
thanks for the links... i just picked up the first one. do you the LCD type is better because of improved power factor correction? as far as i know "simple" SMPS suffer this problem much more than conventional power supplies.
#7 | |
Hey Anonymous1 None of these SMPS represent the value of the one that you hate me informing other DIYers about!!!!!!!!!!!!!! Hope you are not getting commission on any of these "expensive" ones.....:-)
Regards Fin |
#8 | |
If we were both working off commission it would just mean I'm making more. As e-Shakespeare would say..... "To sayeth once is to inform, to sayeth twice is to spam". Not to mention I have about 8 of the supplies from the last link. They work very well and are already in a nice plastic case with an IEC socket. Pay more get more.
#9 |
so what about additional filtering and the power factor correction for supplies that are ment for LCD monitrs?
#10 |
I actually have a couple that are just like those suggested by Anonymous1....but a bit more powerfull and with selectable output voltages (3V to 15V).
I have to agree to agree that they are very handy and neat - especially if your amp is already in a case. However - if you still have to build the amp and get a nice case for it - you might as well put an uncased SMPS in there too. That way you don't waste money on the "nice plastic case with an IEC socket". The additional $20 or so could then be spent on getting a nicer case for the amp - which is the part that will be seen - and not hidden away somewhere. Also - having the supply and regulation closer to the amp (ie. in the same case) would have to be better than it travelling through a meter or two of unshielded cable before it reaches the protection of the metal case. Pay less - get more.......that's my philosophy...and the reason for DIY.
Regards Fin |
| new case for my amp32, let's see your pics! | gychang | Class D | 1 | 30th September 2007 12:11 AM |
| amp11 vs amp32 | nicoch58 | Class D | 0 | 6th March 2007 02:05 PM |
| Amp32 won't work... | v-bro | Class D | 3 | 1st December 2006 08:55 PM |
| amp32-ps.. smd...is singing!!! | nicoch58 | Class D | 20 | 26th November 2006 09:43 PM |
| Smps | rinox | Power Supplies | 0 | 2nd September 2005 10:05 PM |
| Page generated in 0.11956 seconds (82.58% PHP - 17.42% MySQL) with 11 queries |
