| Class D Switching Power Amplifiers and Power D/A conversion |
#571 | |
#572 |
Ok so here is my little list that I put together so far.
1. Remove the zener. - Not sure what it does but everyone says to remove it bc it can blow the amp. 2. Replace the opamp with a ne5532. - Don't know what that does... something with tone control? 3. Replace input caps with 2.2uf metallized polypropylene (google says its 2 L's but firefox says it's 1 L, idk how to spell it.) - Again, I don't know what this does 4. Replace inductors with 10uH 3A toroids. 5. Fix tone control component values. ![]() Code:
R1 (installed 10k, marked 15k): 20k R3 (installed 1k5, marked 1k): 2k2 R4 (installed 1k, marked 1k5): 10k C1 (installed 10n, marked 472): 5.6n C2 (installed 47n, marked 393): 56n C3 (installed and marked 10n/103 near bass pot): 1n C4 (installed and marked 10n/103 near treble pot): 10n Last edited by j0ckinjz; 16th May 2010 at 10:15 PM. |
#573 | |
Base on information from this forum, I have tried both methods. 1. changed the operational with a Ne5532P It depends which op-amp is using, you may try other one. It is interesting experience to change different op-amp, you will have different sound style. Of course, some op-amp is more expensive than the Lepai amp. ![]() 2. Bypass op-amp Just simply change the input resistor value. |
#574 |
Although posted previously, I have re-edited and posted my modifications again to bring them together with other TA-2020 user mods in this thread...
A) changed 3.3uF input Caps to 2.2uF MKT types B) swapped 2200uF for 4700uF Panasonic FC C) changed all other 3.3uF electrolytics for 2.2uF Panasonic FCs D) changed 330uF for 470uF Panasonic FC E) swapped op-amp for NE5532P F) added d.c. trimmers etc. (as per #465 on Pg 47) G) changed tone circuit capacitors (with 1nF, 10nF, 5.6nF and 56nF / 5% bought off eBay) and resistors (20k, 2k2, 10k metal film 0.4W/0.1%) as per post #484, Pg49. Also replaced 430R (marked 100R *2) with wire links. H) changed pots: volume (50k Dual Log RS 249-9288), bass & treble (100k Dual Log Rapid Electronics 65-1466). J) changed inductors for 10uH/2.8A (RS 233-5134). Some issues I encountered... 1. original control knobs did finally come off with (not so) gentle prising but one tone control spindle broke from the slider inside the pot. 2. The new cermet tone control pots had a larger screw thread so had to enlarge the holes on the faceplate. They also sit slightly forward of original ones which means front faceplate now has slight bow in it (about 1-2mm). 3. Had to drill small hole in plastic see-through bezel (around volume control) to take the small metal positioning lug on the new pot. However, because tone pots were slightly forward, was unable to fully tighten fixing screw on volume pot so the positioning lug does not need to mate with new hole! 4. The original plastic control knobs have longitudinal flutting to secure them to the old pots (which are also flutted). However the new pots had plain spindles. Therefore decided to replace control knobs with some aluminium ones I already had in my spares box. |
#575 |
Do you think the Lepai TA2020 is powerful enough to run a pair of Tannoy Reveal 601p speakers? Specs!
8 Ohms -- Nominal Impedance 89dB -- Sensitivity SPL/ 1W @ 1m <0.6% -- Distortion My current speakers are Alesis Monitor Ones: 88db sensitivity at 4 Ohms. They sound great, but they're 15 years old and scuffed up enough that I'd like to replace them. |
#576 |
Hi. New to this forum.
Just got a Lepai TA2020 from ebay and really impressed with the sound. Almost think it's better than my Sonic T-amp. Unfortunately after a few days the left channel has gone quiet. Is there anything I should check before I try and return it? Not much of an electronics type person but can follow instructions and am reasonable with an iron. |
#577 |
Hey guys, I've been looking at this thread for quite a while and decided to buy a Lepai TA2020. It came today and from what I've read, it's better that I remove the zener diode before using it. When I turned it on, there was a pop noise(which I believe is the typical pop sound when it's turned on). I turned it off to plug my speakers and input cable, and after I turned it on, there wasn't any pop noise. I played my music through my MP3 player and no sound came out. I tried it with my laptop, still no sound. Is this due to the removing of the zener diode? I'm using a monitor's power supply that's 12v(12.16v with a multimeter) 5A.
#578 |
Hi everybody!
I bought a lepai lp-2020 some weeks ago. I've played music with it regulary at home until some days ago. Yesterday I build a boombox which it should be installed in. But when I built in all stuffs in it (amplifier, battery, speakers) and decide to use it nothing happened. I've tried it with both the battery and the following net-adaptor but it seems stonedead. The blue led doesn't light and no sound at all from the amplifier. I've opened the amp and can't find any parts that seemes to be burned. Anyone got some ideas or thoughts what may be wrong? Regards Lennan |
#579 |
Very cheap, they fit perfectly. Huge sound improvement.
http://cgi.ebay.it/Choke-coil-for-cl...item3eff1d6665 Last edited by Calamaro; 11th July 2010 at 08:12 AM. |
#580 |
Now i have bin reading this for like 2h. My first Lepia broke after a few days and annother is on the way.
My knowledge on all the names and nummers that u guys type is Zero! So i need, as a few of the members requests, is a turtorial. Not just name on stuff u need. We need detaild picture "where" to put "what" on the Lepia. IT whould really help me and some of the others novis here wrry much. * My first consern is how to NOT make it break after 2 days * Then how to, easyle, switch some parts to make it work better. * Make the instruktions simple, so 5 year old can make it. * Retard as i am, i need pictures, pictures with arrows where to put the part and so on. I live in Sweden so i rather not have som links to ebay, have no time to wait and to pay for shippment. I really hope for an awnser on this post, and i hope my limping english works =) // Gunnar |
| New ta2020 pcb'S | ArjenShenzhen | Vendor's Bazaar | 98 | 14th November 2012 11:39 AM |
| Ta2020 | Bengali | Class D | 0 | 29th September 2007 05:28 AM |
| Eb-ta2020 | opentop | Class D | 16 | 30th May 2005 07:42 AM |
