| Class D Switching Power Amplifiers and Power D/A conversion |
#541 |
Sorry, I didn't know and am still not certain it does not have the 2020.
And If I never open it up again, I can still be unsure and still be in this discussion (OK OK I'm just being a brat) ... no sense muddling up someone's amp with my non 2020 observation. BTW mine is an FM receiver + amp, and maybe those dont have a 2020 ? Thanks all for your patience. Cool. Srinath. |
#542 |
#543 |
mine says FM-103. I guess now I know.
Cool. Srinath. |
#544 |
I'm also busy modding my lepai. now I'm wondering wether the indictor below is a suitable replacment for the inductors.
INDUCTOR, ROD CORE10.0UH 5 A Inductance:10µH Inductance Tolerance:± 25% Max DC Resistance:0.0151ohm DC Current Rating:5A Self Resonant Frequency:50MHz Series:WE-SD Core Material:Ferrite Inductor Case Style:Radial No. of Pins:2 Lead Spacing:18.8mm Case Style:Radial DC Current Max:5A Resistance:15.1mohm Body Diameter:5mm Core Material:Ferrite External Diameter:5.9mm External Length / Height:22.5mm Inductor Type:High Current Lead Length:19mm |
#545 | |
Lepai T-Amp with TA2020 |
#546 |
I plan on running my amp solely off of batteries...therefore, do i need the PSU Capacitor at all of can I just remove it from the circuit. I can't imagine that it has a purpose, since the circuit can take as much juice as it wants from the batteries...
Thanks, Nicholas G. |
#547 | |
#548 |
I have been using the LApai amps for a several months now and really like them. I first had one and then got a second one. I have them hooked to my computer , one is the main front left right channels and the other is for the subwoofer channel.
I made a power supply by using an 8 amp switching supply and hooked that to three large 1 farad stiffening capacitors that are normally used in auto sound systems and it works very good. I can get floor rumbling bass out of the amp. I have found that just one of the bigexterior stiffening capacitors was not enough as when I turned the volume up the voltage wolud drop on the digital readout. When I hoooked three up together and had an 8 amp power supply it could hold the voltage steady even at loud volumes. Just recently blew the main amp out and have ordered two more. I plan on doing some modifications to it like I have read on the forum here, probably starting with the input caps. So after all that I have also been looking into Ultra capacitors. with a few of these one could get up a farad or more worth of capacitors inside the lepai case, What you can do to start is hook three of the 5.5 volt 1 farad ultra capacitor in series so they can handle 16.5 volts max, which wolud be fine for a 12 volt system. With just three of them you could have about 330,000 uf worth of capacitor inside the case of the lapia 2020. Each of them is only 3/4 inches in diameter and about 1/4 inch thick. thats all for now. If any one wants photos let me know. |
#549 |
Hi and sorry I'm late to the party..
I just purchased and received my Lepai 838 and hooked it up on my work PC. Surprisingly good for $14.95. I used the 3A pwr supply from my Linksys cable modem. So the only issue I have with it so far is that the "mega bass" volume is independent of the main volume?!?!? (What were they thinking?) So I want to mod by cutting the tracks to the mega bass pot and tying it directly to the main volume pot so I have the extra trim for "sub" level control. Has anyone else tried or done that? Anyone have a schematic to see if I can pull the sub volume off a buffered location AFTER the main volume? I do apologize if this has been covered but 55 pages are more than I can read in a "reasonable" time frame and I hope to do the mod this weekend.
Troy Thinking positive doesn't make things better, it makes you a better person. |
#550 |
Actually your early for the next party. The 838 doesn't use the tripath 2020 chip and so is unrelated to this thread. It may use Sanyo (LA4625) Toshiba (7240) ics so also not for the Class D section.
| New ta2020 pcb'S | ArjenShenzhen | Vendor's Bazaar | 98 | 14th November 2012 11:39 AM |
| Ta2020 | Bengali | Class D | 0 | 29th September 2007 05:28 AM |
| Eb-ta2020 | opentop | Class D | 16 | 30th May 2005 07:42 AM |
