| Class D Switching Power Amplifiers and Power D/A conversion |
#1371 |
Got my attention here as well.... Looking forward to see how it turns out, do post here when your all done wont you.
#1372 | |
Looks like that item is for 220v and from your flag you're in Canada?
#1373 |
Hi all.
I have a question, hopefully someone can help. I have this amp and want to incorporate the existing on/off toggle and volume functions into a single potentiometer. I have modded several other lepais, but just basically moved the on/off switch to a different spot. I recently bought an on/off volume pot from parts express (see pic) and want to use this. I believe I would run the two power lines into the two leads at the bottom of the pot. The other three would be for the volume. How do I wire those? I assume I'd de-solder the existing volume pot and rewire each of the three leads into the three leads on the new pot? Is it as straightforward as that? Or am I leaving something out? Thank you so much for any help you could recommend. Also, what is the wire soldered to the outside of the volume pot in the circuit board pic earlier in the post? Is that a ground that I would need to solder to the new pot? THANK YOU! |
#1374 |
Yes, it's that straightforward. Just make sure the new pot is connected so a clockwise turn increases the volume.
Yes again. That's a ground wire.
It is error only, and not truth, that shrinks from enquiry. - Thomas Paine |
#1375 |
Thank you, so much. Now I just need to hope my soldering skills are OK
![]() I appreciate the help! |
#1376 | |
I am wondering if similar/same info is available to do the same thing to the 2020B. I have successfully bypassed the tone controls and opamp by installing some nice caps as per this post Lepai T-Amp with TA2020 In the future, however, I would like to bypass the volume control and use the 2020B as a power amp, with a DIY tube pre-amp. I am wondering what resistors I need to change (if any) to achieve optimal gain. |
#1377 |
Hello everyone,
I got hold of my second 2020A+ amp - 111129 PCB - got it used, not in a best shape, broken volume potentiometer, etc.... here is my ( and its ) problem: when the tone switch is pressed, the right channel goes away - left one is good. I checked the switch, it is fully functional on both positions, and both channels. checked for cold solder, re-soldered a few locations, no difference... checked the potentiometers, they also good... when the tone is set to "direct", both channels are fine.... can this be one of the two 4558's on the op-amp? thanks in advance. |
#1378 |
nice, how about adding an USB port in the back or front, for audio storage unit ( usb stick, etc ), or for a RF remote control - I am also curious why are you adding an USB DAC if R-PI has already one built in ( usually it defaults to the HDMI audio, but this can be switched ).
Your project is perfect for getting on-line radio streams, from ShoutCast.for example. I have done something similar with an ITX board, and re-did GeexBox basically from scratch, than I put all the guts in a vintage ( 1970s ) receiver.enclosure.... still got it ![]() Good Luck! |
#1379 | |
The ones on the outside are generally signal in, if you wire both of them the pot will read max at full and min turn and half it's rating in the centre, I've only wired LED's myself but you only need to connect one side. And which one depends on the direction of the pot you want to low the low resistance. I think. Please correct me if I'm spouting ****, this is what I've deduced while working with pots and LEDs. |
#1380 | |
Hello fellow DiY-ers... This is my first post. I've been reading a bunch and I've been learning a ton about these little gems. Thanks to all the contributors.
Currently, I have replaced all my caps with audio grade and changed my inductors. I also removed, cleaned and re-installed my heatsink with better thermal compound. I am at the point where I want to bypass my tone controls and opamps but i want to keep my volume control. I understand that I need to run wires from C20 and C21 to C30 and C31 with 2.2uF caps inline to bypass all of this. I also understand that I need wires from C20 and C21 to the volume pot with 2.2uF cals to enable volume again. My question is... Do i need a total of 4 wires and 4 caps coming off of C20 and C21 to enable bypass and volume? Thanks in advance. Anyone have any pictures of this? Quote:
| New ta2020 pcb'S | ArjenShenzhen | Vendor's Bazaar | 98 | 14th November 2012 11:39 AM |
| Ta2020 | Bengali | Class D | 0 | 29th September 2007 05:28 AM |
| Eb-ta2020 | opentop | Class D | 16 | 30th May 2005 07:42 AM |
