Go Back   Home > Forums > Amplifiers > Class D
Old 12th December 2012, 03:28 PM   #1341
I found the info I needed in post no.925. Amp sounds better now.
Old 12th December 2012, 04:09 PM   #1342
rongon is offline rongon  United States
rongon's Avatar
Is your amp the type with all through-hole components on the board, or is it the newer version with some surface-mount components?
I was thinking of purchasing one of these, but it appears they've changed to surface-mount components, which would make it a lot harder to replace or eliminate parts.
Old 12th December 2012, 04:15 PM   #1343
I have both the original (through hole only) and the model B which is a mix of through hole and surface. I modded the B version easily once I found the info I needed.
Old 13th December 2012, 03:37 PM   #1344
Good day all. i got a Lepai and a question.
I got two pairs of Bru Brown op amps, opa2134 and opa2134pa. seems that 2134 is a single and the 2134Pa is the dual channel, wich of these two model i should use in my Lepai 2020+
Old 13th December 2012, 03:55 PM   #1345
Bare is offline Bare  Canada
Neither.. to be perfectly honest.
Difficult to implement an opamp swap 'properly' and the entire Tone stack in the Lepai is Dubious.. at best.
IMO Lepai works to it's best with ALL the tone crap wiped from the board..
Sad but ohh so true.
Old 13th December 2012, 04:52 PM   #1346
Fynn is offline Fynn  Germany
Yep. And if the gain is too low, you can adjust the gain with the 2 resistors after the decoupling-caps(c20/21) next to the TA2020 chip, according to the datasheet.
They were 15k and 20k for me, which sets the gain to: 12*20k/15k ->16x Vrms.
At 9Vrms you have 20W into 4 ohms / 10W into 8 ohms, which is about maximum for the ta2020. You reach that with 560mV.
I don't know how sensitive you can make the TA2020 though.
Old 13th December 2012, 06:22 PM   #1347
well i am gonna need to read all this pages to understand what i need to do to bypass the tone circuit.. or at least, so i can take it to a eletronic shop and tell them what i need.
Old 13th December 2012, 06:59 PM   #1348
You should look into this one:
LP-2020A+ mod thread
Only covers the newer 2020A+ model, so you can save yourself the 100+page journey
Old 13th December 2012, 11:32 PM   #1349
DIY Audio is your friend:
Amplifier:Lepai T Amp - diyAudio
Old 14th December 2012, 11:08 AM   #1350
I got two pairs of Bru Brown op amps, opa2134 and opa2134pa. seems that 2134 is a single and the 2134Pa is the dual channel, which of these two model i should use in my Lepai 2020+
They are both dual, that's the 2 in 2134. The single is 134 and the quad is 4134.
I agree with Bare, removing the opamps completely is the best thing I did for the sound of my LP-2020A+.
Tyler
New ta2020 pcb'S ArjenShenzhen Vendor's Bazaar 98 14th November 2012 11:39 AM
Ta2020 Bengali Class D 0 29th September 2007 05:28 AM
Eb-ta2020 opentop Class D 16 30th May 2005 07:42 AM
Page generated in 0.10900 seconds (100.00% PHP - 0% MySQL) with 10 queries
Copyright ©1999-2013 diyAudio
