Lepai T-Amp with TA2020
Old 16th September 2010, 02:17 PM   #631
iko is offline iko  Canada
iko's Avatar
To you muppet man.
Old 20th September 2010, 01:05 AM   #632
cjron is offline cjron  Philippines
Originally Posted by denztan View Post
Guys, i have received my new amp as i upgrade the resistors it's giving me a dc offset of 95mv for the right channela and 12volts on the right channel!!! what would cause this to happen? bad capacitor? bad resistor? also i have another 1 that humms as soon as i turn on the amp.. amy help will be much appreciated.
Msj965,
Wassup!?!?! i'll update you if i have any progress w/ the upgrades. i'll have the LM4562 coming in soon
uy LM4562! AYOS....
ojofool@pdvd
Old 20th September 2010, 05:35 AM   #633
savenger1 is offline savenger1  Australia
hey all,
I'm having a problem with my lepai ta2020 in a car installation...
I've wired it directly to the lighter socket on the accessory circuit... it works great with the ignition on 'acc' or 'on', but as soon as I start the car the sound cuts out.
The thing that has me stumped - the LED stays on and there is current going to the amp. What could be causing this? Maybe a grounding problem?... or insufficient amperage from the alternator?
thanks in advance if anyone has any ideas.
Old 20th September 2010, 10:33 AM   #634
alexg is offline alexg  Philippines
alexg's Avatar
If I want to bypass the volume control, am using a preamp, Just install a 100K resistor on the input shunt to ground?
Thanks.
Old 20th September 2010, 03:11 PM   #635
Thanks.
alex, im also using a preamp 12sn7. i just set the lepai to 3oclock and adjust the preamps volume.
Old 21st September 2010, 01:41 AM   #636
alexg's Avatar
I can do that too, but I know that the attenuator installed are of questionable quality, so I might as well bypass it. I will let you know how it goes.
Old 21st September 2010, 03:09 AM   #637
MikeHunt79 is offline MikeHunt79  United Kingdom
MikeHunt79's Avatar
Originally Posted by savenger1 View Post
hey all,
I found the same thing, too much voltage, the Lepai doesn't like being run above 14v.
Old 21st September 2010, 10:18 AM   #638
Yeah looks like that's it... battery shows 12.8v when the car is off, but about 13.9 when the alternator is running.
What is the best way to skim 1v off the circuit so that it can work?
Old 21st September 2010, 02:17 PM   #639
Pano is offline Pano  United States
Pano's Avatar
What problem did you find, Mike? In my experience the TA2020 chip does real at 14V, so no problem in a car. Is it something else in the Lepai?
The TA2024 seems more voltage fragile.
Take the Speaker Voltage Test!
Old 22nd September 2010, 10:18 PM   #640
killmister is offline killmister  France
Default strap
Hello everybody.
Sorry for my poor english !
I'm actually realize a tweak for my lepai.
I sought tips and images and i noticed this : (see pics)
Apparently ,all amp lepai do not have this strap between the two ceramic capacitors .
Someone has an explanation?
Lepai T-Amp with TA2020Hide this!Advertise here!
New ta2020 pcb'S ArjenShenzhen Vendor's Bazaar 98 14th November 2012 12:39 PM
Ta2020 Bengali Class D 0 29th September 2007 06:28 AM
Eb-ta2020 opentop Class D 16 30th May 2005 08:42 AM
Copyright ©1999-2017 diyAudio
