Lepai T-Amp with TA2020
Old 10th July 2009, 06:46 AM   #451
msj965 is offline msj965  United States
Default hello:)
Hi Djnemesi
Just wanna ask what is the outcome when you put the noise suppressor.Pls.can you specify what parts that you replaced and pls include the volts/watt too.sorry if I ask you all this things, coz I'm a begginer when it comes to electronic.
Still waiting for your new pixs!!!
msj
Old 11th July 2009, 03:16 PM   #452
djnemesi is offline djnemesi  Italy
Default damn! already burned!
TA2020 R.I.P.
I was using it with two 4 ohm speakers, trying to push the volume to the limit and....tuuuuk, from one channel come out a DC voltage and all are gone mute. I've done some test end I've found that the power supply (that should be 12V) was over 14V.
Measuring I found that an output of ta2020 is shorted to gnd.
Now I replace the ta2020 putting the overshoot diode
Originally posted by msj965
Hi Djnemesi
msj
Hi! with the suppressor you hear nothing when you turn on the amplifier, after a couple of second you hear a very little tick and the sound come out. I used 1/4W resistor, but you can use what you prefer. The capacitor must be rated for a voltage greater than 5V (I found a 47u, 10V in my drawer)
Old 15th July 2009, 02:44 PM   #453
gurusan is offline gurusan  United States
Send a message via MSN to gurusan
Is there any reason why the 1uF electrolytic connected to pins 27 and 29 has a 100V rating?
Can anyone suggest a suitable replacement as the stock one looks to be of very poor quality.... There are panasonic FC 1uf caps in 25 or 35V ratings I believe, but the 100V rating of the stock cap has me confused.
Old 17th July 2009, 06:00 PM   #454
Red face hello:)
Hi there!!!
Any more updates?
msj
Old 20th July 2009, 07:51 PM   #455
totoelettro is offline totoelettro  Italy
Default bypass
Hi to all,
this is it my first message.
i would like to ask if the bypass mod make loose some watt.
i have make this mod. and i think that the volume is decrease, i use 22k resistor for the bypass and 2.2uf wima for the capacitor.
Regard.
Old 21st July 2009, 08:44 AM   #456
panda360 is offline panda360  Hong Kong
panda360's Avatar
Default Re: bypass
Originally posted by totoelettro
Hi to all,
Regard.
welcome aboard. You can change from 22K to original 8.25K, or some value between. But beware your neighbour will lock your door.
Old 21st July 2009, 12:25 PM   #457
panda360's Avatar
Sorry, my English is too bad. My meaning is your neighbors will knock your door because your volume is too high.
Old 22nd July 2009, 12:28 PM   #458
Default resistor for tone bypass
thanks to all,
i would ask if the value of resistor of 22k is the best for the quality of sound or not. (low resistor more power and worst sound, isn't it?) tnks to all and sorry for the english.
Regard
Old 22nd July 2009, 01:28 PM   #459
panda360's Avatar
Default Re: resistor for tone bypass
thanks to all,
Regard
Pleae refer to TA-2020 spec, the standard values is 22K. R1-Inverting input resistance to provide AC gain in conjunction with RF. This input is biased
at the BIASCAP voltage (approximately 2.4VDC).
Old 24th July 2009, 04:46 AM   #460
Scootxyz is offline Scootxyz  United Kingdom
Hi there
(New to the forum...)
- thanks to everyone who has contributed to this thread. This is really a whole new world to me...
I got my lepai amp a few days ago and I've really grown to like the sound. It's really different to my NAD 3020 and haven't been able to stop listening to it actually.
I got this wee amp as an experiment - and if i liked the tripath sound I was planning to then buy a pre-made amp like the trend or the virtue.one but due to this forum I will probably try to make the most of this amp.
The problem is that I have zero skills in this area. The mod that I really want is the noise suppresion one - but is this really something that a total beginner can learn to do?
If I don't do it I'm worried that my speakers are going to pop out one day when turning the thing on...
Also - I am rnning the preamp out from my NAD into the input of the lepai. Is this ok?
Thanks in advance for any advice...
Lepai T-Amp with TA2020Hide this!Advertise here!
New ta2020 pcb'S ArjenShenzhen Vendor's Bazaar 98 14th November 2012 12:39 PM
Ta2020 Bengali Class D 0 29th September 2007 06:28 AM
Eb-ta2020 opentop Class D 16 30th May 2005 08:42 AM
