Lepai T-Amp with TA2020
Old 4th June 2009, 09:37 AM   #341
whelibob is offline whelibob  Finland
thanks, for the help. so you think the tripath chip is now broken? i used 12V lead battery. adding a new output inductor with higher capacitance wont repair it anymore?
Old 4th June 2009, 09:44 AM   #342
col is offline col  Australia
col's Avatar
12v lead battery? batteries just charged can have voltage up around 14v. Do you have a multimeter? you should measure the voltage. I don't recommend connecting anything over 13.5v.
The constant ticking is the amp trying to reset itself. If you leave it like that it will burn out the chip. If you remove the zener, the little glass orange and black diode near the chip. It will stop the amp resetting. Then you need to work out which inductor is shorted. Follow Mike's directions:
"Try removing the zener diode between pin 18 (fault pin) and pin 11 (I think), and see if you still get ticking.
With the zener gone, try connecting an LED and 2k resistor between pin 18 (fault pin) and GND and see if the LED lights up."
col.
http://www.minirig.org.au
Old 4th June 2009, 09:46 AM   #343
MikeHunt79 is offline MikeHunt79  United Kingdom
MikeHunt79's Avatar
Originally posted by col
I might take out the zener too! Mike, did you replace it with a wire link or just remove it?
col.
I removed it and left it open circuit, it's not needed at all and I'm not sure why they put it in! Take a look at the TA2020 datasheet for the nitty gritty, basically the ticking sound is the amp trying to start up despite there being a problem, and the ticking can lead to a broken TA2020.
I could be the TA2020, it could be a short on the outputs where the inductors and diodes are, I'd remove the zener and wire up the fault LED if you've modded it already, otherwise I'd send it back.
Old 4th June 2009, 09:48 AM   #344
yes i measured the batteryvoltage, it was 12.5V. does anyone have the datasheet link, cant find it at the moment.
cheers
Old 4th June 2009, 10:21 AM   #345
MikeHunt79's Avatar
cheers
www.kafka.elektroda.eu/pdf/tripath/TA2020.pdf
Old 4th June 2009, 10:26 AM   #346
col's Avatar
Mike, which side of the zener is pin 17 and which is 18? I think I might wire a fault led in and glue it to the front.
col.
Old 4th June 2009, 10:38 AM   #347
MikeHunt79's Avatar
col.
The zener goes from pin 11 to pin 18, if you can post a close up of the chip I can highlight it in photoshop for you.
i'll try and get a photo of mine with no zener, but I've only got a camera-phone so it may not work too well...
Old 4th June 2009, 10:56 AM   #348
col's Avatar
Default replacement inductors
I'm sure you can get these in the UK:
http://australia.rs-online.com/web/s...duct&R=2335134
they would be much better than the originals.
col.
Old 4th June 2009, 12:23 PM   #349
MikeHunt79's Avatar
Default Re: replacement inductors
col.
Yep there is a depot pretty near me, so I'll pick up a few next time I'm there, thanks.
I'm now trying to fit a nice allen & bradley pot to the amp as I managed to break the 100k volume pot while trying to remove the front...
Old 4th June 2009, 12:28 PM   #350
col's Avatar
just removed the zener and put a 2k resistor with led on the No18 pin. drilled a hole in the front between the tone controls to mount. So I now have a fault led
col.
Lepai T-Amp with TA2020Hide this!Advertise here!
New ta2020 pcb'S ArjenShenzhen Vendor's Bazaar 98 14th November 2012 11:39 AM
Ta2020 Bengali Class D 0 29th September 2007 05:28 AM
Eb-ta2020 opentop Class D 16 30th May 2005 07:42 AM
Copyright ©1999-2017 diyAudio
