Lepai T-Amp with TA2020
Old 31st August 2007, 11:22 AM   #161
gychang is offline gychang  United States
Originally posted by Lostcause
I modded mine to the point were most of the board became redundant, to that end, its quite a big box for a small amp!
an amp6 is better and cheaper in the long run otherwise......
thanks, gychang
Old 15th March 2008, 07:37 AM   #162
Loaded4th is offline Loaded4th  United States
Hi Fin;
I've just received a Lepai 2.1 Amp that I'm using with a Visteon HD Radio. Both of these were purchased through ebay.
The Amp is listed as an S07 Motorcycle amplifier 200 watts 12V.
Prior to getting a bass unit, I'd be interested to know if you have used the sub-woofer connection and whether it can be directly hooked up to the speaker or if it requires a powered unit.
Thanks in advance...
Old 15th March 2008, 07:53 AM   #163
dweekie is offline dweekie  United States
200W? Seriously?
Old 15th March 2008, 10:32 PM   #164
thomascurtis is offline thomascurtis  Netherlands
S07 Motorcycle amplifier is this a tripath ?
Old 16th March 2008, 06:34 AM   #165
I don't know what fuzzy math they used to compute 200W (100 + 100), as the input connector states 12v 2A. I know a lot of manufacturer's quote peak power, but this seems way off.
Old 16th March 2008, 06:34 AM   #166
Re<<S07 Motorcycle amplifier is this a tripath ?>>
I would guess that it is, but I have not taken the unit apart (yet!).
It's been a very long time since my involvement in amplifiers, my initial foray used the newly introduced silicon transistor in the 60's.
Old 17th March 2008, 03:08 AM   #167
Fin is offline Fin
Fin's Avatar
Originally posted by Loaded4th
Hi Fin;
Sorry - I've never seen that particular amp. I only have the one mentioned earlier in this thread.
Fin
Old 21st March 2008, 07:40 AM   #168
The Lepai 2.1 Amp does have a powered sub-woofer. I initially wanted clarification because this unit is also bundled with a powered sub-woofer. I could of initially manually checked it but thought I could get a quick answer--apologies for the amp type mix-up.
Old 11th April 2008, 08:12 AM   #169
batinal is offline batinal  South Korea
batinal's Avatar
Default lepai amp supplier
ping Fin,
Can you e-mail me how to order the amp so that I can join you and share the pleasure?
Thanks in advance.
Kay
Old 11th April 2008, 02:38 PM   #170
Default The Lepai 2.1 motorcycle amp
This is not a tripath amp. Motorcycle amp.
Lepai T-Amp with TA2020Hide this!Advertise here!
New ta2020 pcb'S ArjenShenzhen Vendor's Bazaar 98 14th November 2012 11:39 AM
Ta2020 Bengali Class D 0 29th September 2007 05:28 AM
Eb-ta2020 opentop Class D 16 30th May 2005 07:42 AM
Copyright ©1999-2017 diyAudio
