| Class D Switching Power Amplifiers and Power D/A conversion |
#11 | ||
Baldin!
BTW: Quote:
#12 |
Account Disabled
Bit late in the day..... What Powerbecker/Heinz drew....
Same idea, mine is more stupid though... DNA |
#13 |
Account Disabled
Oooops no picture....
DNA |
#14 |
powerbecker:
Thanks .... that cleared it up Think I'll try that first, as it will be easiest to implemtent on the current PCB Pafi The circuit is "right" ... the divider is conected to - and not + as I wrote! Yes the output is high = 10,4V on pin 7 which is connected to the base of the following Q13. Otherwise like your approach .... will try that on the next D thing .... didn't think of the pre-bias, and thought I couldn't trip a BJT directly from the current sensing resistor.
#15 | ||
#16 |
The 10,4V is measured with Q13 dismounted.
Don't know where the basis resistor for Q13 went! (as the LM319 is an open collector output, Q13 will be biased through R57 (2k2) and will still work, though it was not intended to be designed this way..... think I will increase R57 to 10k to lower the basis current in Q13!! Problem is that when plus is tied to ground (or no current is running in the sense resistor), then minus is higher (set by the divider), but the output is high (10,4 V) Now that I'm digging a bit, I have found the simulations .... and find that these are using a TL072 as comparator .... and that it includes a bias resistor for Q13 The only reason I'm using the LM319 in this place is because I had one half free, as the other half is used in the oscillator |
#17 | |
| Problems with amp | bluiezaccord | Car Audio | 2 | 31st March 2008 08:20 PM |
| HK AVR 335 Problems | utjay2008 | Solid State | 0 | 21st October 2007 02:26 AM |
| Nak dvd-10s problems | MadMutt | Digital Source | 8 | 26th March 2007 10:06 AM |
| help me about comparator(such as lm319,lm339) | canghai | Class D | 1 | 20th May 2005 09:00 AM |
| Help on using LM319 in Single Supply Configuration | Workhorse | Class D | 4 | 13th December 2004 11:46 AM |
| Page generated in 0.09129 seconds (86.20% PHP - 13.80% MySQL) with 11 queries |
