Big-t
Big-t
Old 11th January 2008, 09:13 AM   #81
Eva is offline Eva  Spain
Eva's Avatar
Send a message via MSN to Eva
Primary waveform looks rather strange. Is your chasis AC (or DC) coupled to ground? Also, secondary waveform reveals that you are not waiting for complete resonance before turning on the opposite side.
BTW: Yesterday I toasted a 3KW power factor corrector prototype (80-280V AC input, 415V DC output) because I soldered one end of a jumper to the wrong place. This is prone to fireworks
I use to feel like the small child in The Emperor's New Clothes tale
Old 11th January 2008, 09:30 AM   #82
luka is offline luka  Slovenia
luka's Avatar
Big-t
Hi
Was diode only thing that was destroyed?
"safety bulb in series with the supply glowed"
where and what type did you have?
home page @ http://www.classdaudio.tk/ @ 24/7 all year long
I FEEL SLOVENIA
Old 11th January 2008, 09:37 AM   #83
djQUAN is offline djQUAN  Philippines
Send a message via MSN to djQUAN Send a message via Yahoo to djQUAN
the chassis is connected directly to ground right at the input terminals via #14 wire. board ground is connected to terminal via two 8ga wires.
tripath module ground is also directly connected to ground.
the first waveform pic is the waveform right at the mosfet gate.
second pic is right at the primary (mosfet drain)
third is after the half bridge of the T amp
luka,
I'm using a headlight bulb with both high and low beam in parallel. the whole thing is connected between car battery + and amp input.
nothing was toasted. the diode seems to be still functional. just a black mark on the heatsink and chassis.
Old 11th January 2008, 09:47 AM   #84
luka's Avatar
Big-t
Hi
Ahh ok thats good, good diode This time clean chassis of all "can't be there" stuff
I FEEL SLOVENIA
Old 11th January 2008, 09:49 AM   #85
here are some secondary waveforms:
first trafo secondary:
second trafo secondary:
second trafo waveform X10 mag:
Old 11th January 2008, 09:50 AM   #86
Originally posted by luka
Hi
I just stumbled upon my diode somewhere....it's rated at 75A 1200V
Old 11th January 2008, 09:59 AM   #87
luka's Avatar
Big-t
Hi
loool, hope you won't use it?? What is its forward voltage drop + is it even fast?
I FEEL SLOVENIA
Old 11th January 2008, 10:02 AM   #88
that's what I'm using here right now.
it's fast recovery. voltage drop in the diode test using DMM is about 300mV.
another note: transformers stay cold.
output inductors get perceptively warm. that's barely warm. residual at speaker outputs is rather high though at 3Vpk (a clean sine wave at the osc freq of the tripath chip) which has always been there even when I first built it.
Old 11th January 2008, 11:41 AM   #89
Eva's Avatar
I told you the PSU was overkill. You can power two or three class D modules with it, maybe four
Also, you don't need litz style wire on class D output toroid inductors. It should have taken quite a lot of time and effort to wind them that way
Old 11th January 2008, 12:26 PM   #90
I was future-proofing the supply. so when I get a bigger amplifier module, no need to make another supply.
alas, this thing just caught on fire!
well, sort of. I was having weird waveforms at the output when moderately loaded so I adjusted the freq and increased it a bit.
the waveform was a normal square wave but has a huge 40v peak with flat tops during deadtime so I thought "hey, let's increase the freq!" so I did and it worked fine for a couple of minutes then the diodes (1N4937) at the primaries (for voltage doubling for the gate supply) smoked and I have a few delaminated copper foil and four dead diodes. haven't checked for any other damages but it blew the 60A fuse at the power input so something must have also blown.
btw, I have lots of litz wire. it also makes winding the coils easy as they are easier to bend.
Big-tHide this!Advertise here!
