Big-t
Big-t
Old 26th October 2006, 10:23 AM   #11
pinkmouse is offline pinkmouse  Europe
pinkmouse's Avatar
Big-t
I like the blue power LED on your battery screwdriver!
Rick: Oh Cliff / Sometimes it must be difficult not to feel as if / You really are a cliff / when fascists keep trying to push you over it! / Are they the lemmings / Or are you, Cliff? / Or are you Cliff?
Old 26th October 2006, 10:26 AM   #12
djQUAN is offline djQUAN  Philippines
Send a message via MSN to djQUAN Send a message via Yahoo to djQUAN
yeah, I just noticed that it got into the pic when I posted it already. :P I think I have to change it someday. it blinds me when I'm drilling something.
it WAS battery powered. the 6V battery failed so I rewound the motor to run on 12V and added wires and clamps to a SMPS or car battery. it's a good thing to not need to drag long extension cords in the garage.
Old 26th October 2006, 04:43 PM   #13
BTW guys, I'm having a bit of a issue on the output and it worries me a bit.......
the output signal contains a constant sine wave of about 5V peak at 625kHz (the idle freq) it is a bit high for my liking and I'm wondering if it would cause havoc of my car's engine computer or other stuff.
the output inductor measures about 10uH and the 5W zobel resistor along with the main inductors get a bit warm to the touch but not hot. you can just feel it get a bit warm.
also, I'm not sure if it is normal with high power T amps since my amp2 also has the same problem but one channel has 3V peak and another at 4V peak. I originally thought it was due to the inductors wound with some turns overlapping so I rewound it (now with litz wire) and it still had the same problem.
it doesn't seem to affect the sound quality though.
when this amp is done, this will power my current subs and the amp2 will be moved to the front separates and my P3A amp to the rears. this concerns me since the speaker wires run along the door sills along with the stock wiring. wondering if the high freq sine waves will be coupled and interfere with the car's electrical stuff.
Old 26th October 2006, 04:49 PM   #14
BWRX is offline BWRX  United States
diyAudio Moderator Emeritus
BWRX's Avatar
Try increasing the value of the filter inductors. What value caps are you using in the output filter and what load impedance will the amp be driving?
Brian
Old 26th October 2006, 04:53 PM   #15
I can't recall but they are the stock values provided and I think are 0.1uF and 22ohms + 0.22uF for the zobel circuit.
Old 26th October 2006, 05:28 PM   #16
BWRX's Avatar
I hope it's not a 0.1uF cap. It should be more like 0.47uF.
You can try to get some toroid cores with a higher permeability so you can get higher inductance without overlapping the windings.
22 ohms for a zobel/snubber is fairly high, but if it's rated at 5W and it's only getting warm then there's nothing to worry about.
Brian
Old 26th October 2006, 05:43 PM   #17
well, I do remember that it is 0.1uF in parallel with the load. I could try placing another cap in parallel right on the speaker terminals?
the main problem here is that toroids (of any type) is hard to come by here let alone specialized types so I would like to use the stock cores as much as possible.
Old 26th October 2006, 06:10 PM   #18
BWRX's Avatar
That 0.1uF isn't the capacitor I was talking about. The caps I'm talking about are the C in the LC filter. They're connected between the output inductor and ground and should have a value around 0.47uF. I don't know what type Jan supplied with those kits.
Technically, the 0.1uF in parallel with the load is part of the output filter though.
Brian
Old 26th October 2006, 06:16 PM   #19
that I what I was talking about. they are mounted on the PCB. they are film types at 100V.
maybe another cap across the speaker terminals (0.47uF) would help? I could try that this weekend. or should it be that the 0.47uF cap be mounted right on the PCB?
Old 26th October 2006, 06:33 PM   #20
BWRX's Avatar
This amp has 2 single ended outputs, correct? And you're sure that the LC filter values are 10uH and 0.1uF? If those are true, then I would try changing the 0.1uF caps to 0.47uF (or a bit higher for 2 ohms) 100V.
Brian
Big-tHide this!Advertise here!
