Big-t
Big-t
Old 12th January 2008, 04:44 PM   #111
djQUAN is offline djQUAN  Philippines
Send a message via MSN to djQUAN Send a message via Yahoo to djQUAN
this thread seems to have turned into something that should be put in the powersupply design forum.
here's the latest waveforms.....
freq is dropped to 27.4kHz dead time is the same and gate drive supply is now driven from an aux winding.
edit: current draw at no load condition is now at around 400mA. that is the entire supply including a small fan, gate drive supply and PWM controller. only two LED's connected at the output via 10K resistors per rail.
and here's a closeup of the gate supply:
TO-220 device is a LM317 which provides regulated 17.5V to the totem poles. you can see the aux winding going to one ferrite bead and four 1N4937 diodes mounted vertically arranged as a bridge.
gate supply remains regulated down to 11V input.
Old 12th January 2008, 05:18 PM   #112
Eva is offline Eva  Spain
Eva's Avatar
Send a message via MSN to Eva
Approved!
I use to feel like the small child in The Emperor's New Clothes tale
Old 12th January 2008, 05:22 PM   #113
Originally posted by Eva
Approved!
great! I thought I had to redo everything when you saw the layout.
at moderate levels, the waveforms barely change except for some tiny spikes here and there but nothing seems to go crazy. next on the list is power testing in the car.
BTW, the waveforms were taken with the amplifier module connected and running.
Old 12th January 2008, 08:57 PM   #114
luka is offline luka  Slovenia
luka's Avatar
Big-t
Hi
Now this looks even better then before, good job. But what heat you will save with fest with that voltage, you will lose in diodes, but voltage drop on fets will be smaller...
home page @ http://www.classdaudio.tk/ @ 24/7 all year long
I FEEL SLOVENIA
Old 13th January 2008, 04:16 AM   #115
well, I could have used better diodes but this was the best I could find here so I have no choice. besides, it seems to work well.
Old 13th January 2008, 08:02 AM   #116
luka's Avatar
Big-t
Hi
I don't doubt their good working, just that they are way too big for this kind of operation, but as you said if this is only thing you can get...have same problems here
Now test in car? movie, movie...
I FEEL SLOVENIA
Old 13th January 2008, 08:38 AM   #117
soon. just be patient.
I'm going to rebuild the entire setup of my car before this thing can go in so you'll have to wait.
Old 13th January 2008, 09:58 AM   #118
it's just missing the bottom cover....
temp sensor already installed.
added a few SMD caps at the input terminals to reduce EMI
almost finished case....(brown part is acrylic with paper cover still there)
beside the old case....
Old 14th January 2008, 07:46 PM   #119
MikeHunt79 is offline MikeHunt79  United Kingdom
MikeHunt79's Avatar
Hey, I'vd read up on how SMPS work, and now I know roughly how this works makes it more impressive...
I like that it is far smaller than your original set up... so are you getting nice solid rails now?
Old 15th January 2008, 02:54 AM   #120
that's great....
this is what started it all for me.
I haven't done some power testing yet. the entire car setup of mine is out and I have to rebuild a new amprack. will update as to how it goes.
Big-tHide this!Advertise here!
