First time Class D-IYer - Page 2 - diyAudio
Go Back   Home > Forums > Amplifiers > Class D
Old 25th October 2006, 01:39 PM   #11
v-bro is offline v-bro  Netherlands
v-bro's Avatar
I wouldn't worry about 8 ohm loads, all it can result in is a bit less power, but since it has plenty i would change nothing and just enjoy it. (a 4 ohm capable amp can drive tougher loads and will keep up the compatibility of the amp...)
Max. cone displacement can be several foot on any speaker!Too bad it can be done only once......
Old 25th October 2006, 01:40 PM   #12
niiico is offline niiico  France
I'm speaking about the output caps.
For the input caps, you may test the Paper in Oil caps without any problems.
Old 25th October 2006, 02:14 PM   #13
alexmoose's Avatar
alright, sounds good! now for a far simpler question!
does anyone seggest a good power transformer for this amplifier (Preferably a torodial)? because I have found one with a 25v secondary, rated at 300VA, it has the right current, but it would require unwinding quite a few wires off the transformer to make it suitable. does anyone seggest a transformer? (in a decent price range, the 25v 300VA is 19.95)
Old 25th October 2006, 03:18 PM   #14
I may be wrong, but...
25 V AC secondary means 25x1.41=35.25 V DC at least.
And this is far beyond specs. (33V is the maximum voltage before damaging the amp)
To get a 24V DC you must find a transformer with 18V AC output.
Old 25th October 2006, 03:56 PM   #15
heady is offline heady  Singapore
Originally posted by alexmoose
I was thinking and almost positive I going to make Amp5. I looked at amp 9, but was dis-enchanted when I saw it is designed for a 4 ohm load, has anyone run it with an 8-ohm load? do you still seggest the amp9 for my 8-ohm speakers?
Just finished a amp5 and using it to drive 8ohm speakers. Sounds very good and goes louder than I need. Easy to build as well.
Old 25th October 2006, 06:01 PM   #16
alexmoose's Avatar
I know, you're right, which is why I would have to resort to unwinding part of the Transformer, but if anyone had a good one in mind I am open to seggestions
Heady,
how does the high-range of Amp5 hold up? it looks like the distortion kinda looses it above 5k, does it sound really nice in the high range?
Old 25th October 2006, 09:50 PM   #17
v-bro's Avatar
If it's a really good deal on that tranny you can try more diodes in the rectifier bridge to drop the voltage a little....
Old 25th October 2006, 10:01 PM   #18
v-bro's Avatar
I don't think this solution can be rendered as very "audiophile" though...
This link shows that the chip can handle an absolute maximum of 40Vdc:
http://www.tripath.com/downloads/TA2022.pdf
Maybe the best way to go is indeed unwinding the secondary on the tranny...
Or maybe there's the possibility you can upgrade a few components to be able to handle it, but beware, the chip/amp/parts can have a very short lifespan this way...
Old 26th October 2006, 01:26 AM   #19
alexmoose's Avatar
I think the best chance is to add ADDITIONAL windings to the transformer secondary in the reverse direction, then nothing would be lost powerwise. I think I would need to add about 70 windings in the oppisite direction to lower the secondary from 28v tro 18v with, the transformer has a power rating of 500VA, so at 19.95, its a really good deal
Old 26th October 2006, 01:49 AM   #20
Heady,
When I first built the amp, I used the supplied electrolytics for the input caps. The treble was horrible, very artificial and screechy.
I then substituted them for a pair of Solens polypropylene caps which was by-passed with Vishay-Roedenstein caps and the high end really cleaned up. Now with the burn-in, the high end sounds very tame, maybe a little too tame but that could be due to my other equipment.
You can see the pics of the mods I made in this link:
http://www.41hz.com/Forums/topic.asp?TOPIC_ID=742
dead time, and class D distortion zenmasterbrian Class D 90 22nd January 2007 12:47 PM
delay time is it normal for class d amps djkiller1 Class D 1 7th December 2004 04:04 AM
1st time DIY Class A jab23 Solid State 18 23rd March 2002 11:52 AM
Copyright 1999-2017 diyAudio
