Go Back   Home > Forums > Amplifiers > Class D
Old 22nd October 2006, 05:09 PM   #1
Default T-amp, too loud, too soon
Hi all
I have been using T-amp for some time and I am very happy with it. But after doing the input mod (2uF paper in oil) my amp gets too loud too soon. I’m using the stock pot (50K). There no more smooth increase in loudness. My amp gets from silent (7 o’clock) to pretty loud (9 o’clock) and then slowly increases volume in the remaining travel. I’ve tried 2 stock T-amp pots and it’s the same thing. How do I fix this? Other value of pot (20k,100k) ? Or put a resistor somewhere? I removed R01 and R02 in stealth mod, so maybe that’s the problem?
Old 22nd October 2006, 06:22 PM   #2
luka is offline luka  Slovenia
luka's Avatar
Send a message via MSN to luka
Well I would change back the cap and see if that is the couse of your problem.
home page @ http://www.classdaudio.co.cc @ 24/7 all year long
I FEEL SLOVENIA
Old 22nd October 2006, 08:31 PM   #3
But then I would lose the bass benefits of the mod! Hundreds of people have done this mod and I have never seen reports of this behavior. I will try it if nothing else helps, thanks.
Old 22nd October 2006, 08:47 PM   #4
kubeek is offline kubeek  Czech Republic
Send a message via ICQ to kubeek
I guess you didn´t catch the concept. You change it back to see if the loudness effect remains or not. Only then you can see if it is caused by the new cap or something else...
Old 22nd October 2006, 09:35 PM   #5
cpemma is offline cpemma  United Kingdom
You've done the stealth mod, check your board breaks and wiring very carefully against the graphics in the 'Input Mods' page here.
I've done this using an ordinary dual 47k log pot no problems with volume slope.
Old 22nd October 2006, 10:12 PM   #6
Pano is offline Pano  United States
Pano's Avatar
Sounds like a wiring problem at the pot.
Can you post a diagram of how you have wired it?
Don't post what you think you did, post what you really did. Trace your wiring.
Take the Speaker Voltage Test!
Old 23rd October 2006, 10:50 AM   #7
Here is a diagram and a pic. Be gentle it's my first soldering job.
Old 23rd October 2006, 10:52 AM   #8
btw - How do I attach multiple files to 1 post ?
Old 23rd October 2006, 11:22 AM   #9
deiksac is offline deiksac  Czech Republic
Send a message via ICQ to deiksac
What I can say from the picture and the schema - you have just added extra caps in series to existing caps placed on the sonic impact board - this cant bring you any bass benefit, you gotta replace those onboard stock caps - which is a pretty tedious work since they are ver very small and the copper traces below the get destroyed pretty easily
Old 23rd October 2006, 12:21 PM   #10
I removed R01 & R02 and removed and briged C3&4. The bass benifits are there, the mod is working fine, but the volume is the problem.
For those that like it loud RacerXtreme Multi-Way 25 12th September 2007 04:02 AM
How loud can you go? paulspencer Multi-Way 7 28th June 2007 04:12 AM
can fr125s do loud? NurEinTier Full Range 20 8th December 2006 06:58 PM
BIG LOUD 3 way? xstephanx Multi-Way 17 4th July 2006 09:43 PM
how loud do i need to go badger Multi-Way 6 8th January 2002 07:24 PM
Page generated in 0.12040 seconds (80.52% PHP - 19.48% MySQL) with 11 queries
