New D-Amp Web Site! - Page 3 - diyAudio
Go Back   Home > Forums > Amplifiers > Class D
Old 16th October 2006, 07:18 PM   #21
sovadk is offline sovadk  Denmark
sovadk's Avatar
The PDF User download at the following link is broken:
http://www.d-amp.com/serie_hvi.htm
Old 16th October 2006, 07:40 PM   #22
fredos is offline fredos  Canada
We will finish to re-do the user manual to have the same look as the web site...comming in fews hours!
DLS series in fews minutes...
Fred
Still work hard!
www.d-amp.com
Old 16th October 2006, 09:38 PM   #23
Nice site. Looks cool.
I went to this page:
http://www.d-amp.com/serie_dls_multichannel.htm
and the link to the description/manual was dead.
Posting here you will attract crossover home users, therefore I suggest you flag on your home page what you consider your most viable option for home use.
Red
Old 16th October 2006, 09:38 PM   #24
kvintus is offline kvintus  Finland
Send a message via ICQ to kvintus
None of the pdf files work.
At the bottom of the pages the "Tous droits réservés" should maybe read "All rights reserved" when browsing the english pages and something equivalent when broesing in spanish.
I already sent you an e-mail asking for prices.
All the best,
Anders Haggblom
Kainos Media
Finland
Old 16th October 2006, 10:28 PM   #25
On the English home page, the header says "Experiment the true power of digital amplification." Don't you mean "experience" - apart from other comments in this thread questioning whether class D can be represented as 'digital amplification'?
Red
Old 16th October 2006, 10:39 PM   #26
Like I told again, Digital Amplification is the registred mark 8 years agao, before polemic about class d as not ''digital'' (even with 1 bit convertion??) but analogue in term of analogue input and digital output. The name of the company have been do with this name, so I won't make any change in this... Anyways, Crown, Crest, Peavey do the same, so...Like you know, the name do not give result, that's the products! Thanks to all for comment about the new web page, just put it online because lot of customer whant information about news products and ask why their news products was not yet on the web page...DLS serie was release about a years now and still not on web page...And lot of inquiry about serie one, and lot of time to told customer that was replace by the DLS serie...
I know that not every body agree with the name, but like I told, it was registred 8 years ago! And anyways, for now, that a good marketing!
Fredos
www.d-amp.com
Old 17th October 2006, 04:31 AM   #27
New picture in ''realisation'' just added...
Fredos
www.d-amp.com
Old 17th October 2006, 07:23 AM   #28
DcibeL is offline DcibeL  Canada
DcibeL's Avatar
Originally posted by fredos
Dont forget that music is about 30% duty cycle of full power...Reduce your 360W by this and you got 110 Watts of heat... Add on this the lose in some IC, specialy the gate drivers and some linear regulator and you will get worst case 120 watts of heat for 2 channel...At full music power...And I can told you that for as now, nobody use it even near clipping...Thanks to BSS and DBX drive rack! Even in big rave, amplifier still cold after 12 hours of work!
Oh I understand this completely, and I was implying "full output" to be rail to rail continuous sinusoidal output. However I do think that the amplifiers cooling system should be able to remove the amount of heat generated in this scenario, since amplifiers are rated at continuous RMS power, not music power. It looks like one hell of an amp nonetheless; it may be the highest power is a single amp I've seen ever seen. I don't even want to know the DC rail voltages.
We dont have digital spectrum analyser yet...We only have a good old analogue HP
I use a CAD$60,000 digital spectrum analyzer at work. It's just a dream to work with. Jealous?
Old 17th October 2006, 06:04 PM   #29
Ha ha! DcibeL...Yeah I'm jalous! Just need to sell fews more amps to got a 100 000$ one!
Supply rail is 300V with full bridge ground referenced power stage...Peak voltage with music at output is near +/-240V, because modulation factor is .9, for now, only the 18B2400 from TR (www.tr.ca) can support it all night without faillure at near amplifier clipping....
Yes cooling was design to support full power, but after 15 minute, thermal protection reduce power to about 1300 watts RMS, if signal did not cross 0V output. If amplifier go over 82 celcius, power is reduced by 6DB and shut down occure at 90 celcius.
Like I told you, under music program, amplifier temp never reach more than 50 celcius, even with a Crown heater under!
I use 2 bar of aluminium of 1,25"X0,75"X12" with added fine on the side to take the heat from mosfet and 3 16CFM fans to evacuate heat...Make the calcul about aluminium mass and a dissipation surface of 22 square inch with 48CFM total (for each channel) and you will see that even with 360 watts of dissipation at full power, you will need a minimum of 45 minute before to reach 90 celcius in a 25 celcius room...And dont forget that in 1U case, air is forced to pass in the heat sink!
Wish that help you to figure thermal management of the amplifier!
Just to let you know too that the timer for the RMS power detection reset each time that output signal pass to the 0V...What happen at maximum every 15 sec maximum with music signal! So no worry about RMS limiter under a party!
Fredos
www.d-amp.com
Old 17th October 2006, 08:28 PM   #30
DcibeL's Avatar
Wow, that's more information than I could have ever hoped for . Thanks!.
I can't wait to see what your DIY modules have to offer.
Looking for site beamnet Tubes / Valves 3 19th September 2007 03:26 AM
is the site ok? cowanrg Everything Else 4 6th December 2005 02:34 AM
New web site nickgreek Everything Else 0 11th October 2003 03:44 PM
New site Jason Everything Else 42 1st July 2002 11:14 AM
my site filippo22 Multi-Way 0 13th July 2001 10:53 AM
Copyright ©1999-2017 diyAudio
