Class D Amp Photo Gallery - Page 50 - diyAudio
Go Back   Home > Forums > Amplifiers > Class D
Old 21st January 2012, 07:53 PM   #491
whaleman's Avatar
Originally Posted by vmed_cha_gr View Post
Finished my HifiMeDiy T2 2x100 amp.
The box is painted in black glossy color and it comes from a broken pc dvd driver.
Front panel is a nice piece of wood that comes from my sons toys.
Sound is perfect with no mods & it is driven by a tube-class "A" pre-amp using 2x ECC88CC Siemens tubes from the 70's.
Vassilis
Nice use of recycled parts and nice outcome! I recognize those rubber feet, use them on my amps all the time.
WHALEMAN
The Cathedral Speaker Co.
Old 21st January 2012, 08:01 PM   #492
Mind sharing where you get the rubber feet?
Thanks,
Rod
Old 21st January 2012, 09:12 PM   #493
whaleman's Avatar
Thanks,
Rod
These are it: Penn-Elcom F1691 Rubber Cabinet Foot 1" Dia. x 1" H 260-774
Good luck.
WHALEMAN
Old 21st January 2012, 10:05 PM   #494
Thanks very much. I have a T4 and Connex supply in transit from HiFiMeDIY. Really looking forward to it. Will be the first amp I've built since 1958. Things have changed a bit since then!
Rod
Old 22nd January 2012, 04:35 PM   #495
Vassilis
forgot to mention that it is powered by a mw 27dc power supply.
Old 24th January 2012, 02:25 PM   #496
sst4270 is offline sst4270  United States
Default Rubber Feet
@NWBoater
I'd recommend McMaster-Carr $0.60 ea for a pack of 25.
McMaster-Carr
P/N 9540K38
And if you can accept 3/4" instead of 1" diameter the price drops in half from that... P/N: 9540K49
-Steve
Old 24th January 2012, 07:22 PM   #497
Originally Posted by sst4270 View Post
@NWBoater
McMaster-Carr
P/N 9540K38
-Steve
Thanks Steve. McMaster Carr is a great resource, but at this time I don't need anything else from them. Shipping etc to Canada is expensive so will probably go with the Parts Express ones because I'll be getting other stuff for the amp from them. Will sure keep McMaster Carr in mind for the future though.
Only thing I'm not sure of getting from Parts Express though is the 50k audio taper dual volume pot 50K Audio Taper Stereo Potentiometer 1/4" Shaft 023-650 Trying to decide if something else may really be better - only thing I can think of is the linearity between the 2 sections to maintain stereo balance. But perhaps asking about the need for better volume control quality is a little like asking about Interconnects!
Thanks for any suggestions.
Rod
Old 24th January 2012, 08:11 PM   #498
MrSlim is offline MrSlim  Canada
Rod
something like an Alps RK97 will probably be a lot nicer for you, and definitely have a lot better balance between the channels..
Old 25th January 2012, 12:31 AM   #499
Thanks much - will probably go that way. Interesting that in the Mouser catalog they call the mounting style "Through Hole" instead of panel mount. It has threads and hopefully they are a standard size so that I can panel mount it.
Rod
Old 25th January 2012, 02:29 AM   #500
Rod
The "Through hole" mounting style is for the connector pins, meaning that they are designed to be installed in a printed circuit board(vs point to point solder lugs on the Parts express part). There's nothing stopping you from mounting the pot itself on a panel, and connecting wires to the pins though (and that is actually how I am doing it for some headphone amps myself). You can get all of the physical measurements of the part from the documents on the Mouser site (or at Alps themselves) to get the hole size for the panel(which I also needed to do..)
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2016 DragonByte Technologies Ltd.
Copyright 1999-2016 diyAudio
