Go Back   Home > Forums > Amplifiers > Class D
Old 26th October 2010, 11:49 PM   #301
lazzer408's Avatar
Originally Posted by Chris Adams View Post
I bought the 20-12123N (12x12x3) with clear alodine finish for $43. With shipping from CA to VT it was $52 and change. The finish isn't as nice as anodized but perfectly acceptable.
And it came vented? Their price list showed $25 extra to punch vent holes.
Old 27th October 2010, 01:50 AM   #302
Yes, at first I found it a bit confusing also. Look at this link Par-Metal This is the way the 20 series comes (with the vents). Actually, single vent rows on the top like mine, not the double as shown. If you need them to punch holes or do any other metal work, it is extra.
Made a mistake on the shipping from CA, they are in NJ. So NJ to VT still $52 and change total. To Chicago, maybe a bit more but they are only a few lbs.
Old 27th October 2010, 02:38 AM   #303
theAnonymous1's Avatar
My only qualm with their cases is the texture of the aluminum; it has a very coarse grain to it.
On the black anodized versions you will actually see a light powdery residue (skin, eww) if you rub your fingers across it. I hate to even touch the thing, it just feels bad.
"If you don't like funerals don't kick sand in Ninja's face." - Ninja
Old 30th October 2010, 03:46 PM   #304
Twain is offline Twain  Switzerland
Default Integrated Class D Amp with Media Player
Dear All
I'm currently working on a design for an integrated class D amp with media player. Now I would like to share my work with you.
Supply section:
- 2x 150W AC/DC switched converter with wide range input
- buffer section with low impedance capacitors
- filter section with hf filter capacitors
Power amp section:
- circuitry based on IRF reference design
- 2x150W @4Ohm
- half bridge
Media player section:
- MP3/AAC/WMA/FLAC from SD card or USB stick
- Webradio with LAN streaming
- AMOLED touchdisplay
Appliance:
- 2 rotary encoder with push function for standby, volume, source and mute
Case:
- anodised CNC machined aluminium
So far the mechanical design is done. The development work on the electronics and the firmware is ongoing.
I'll keep you updated.
Cheers
Twain
Old 30th October 2010, 06:14 PM   #305
Will it be running RockBox or was that just a convenient image to use?
Old 30th October 2010, 06:38 PM   #306
I'm actually testing a Linux/ARM platform with Rockbox running on but it's not yet settled because the OS is a bit laggy on this particular hardware. As an alternative I see an approach on same platform without OS but dedicated hardware decoder. Here the HMI wouldn't be so nice but also less laggy.
Old 31st October 2010, 11:51 PM   #307
nigelwright7557's Avatar
First go at class d, this one is 100watts using IRS2092.
http://www.murtonpikesystems.co.uk PCBCAD40 pcb design software.
Old 1st November 2010, 03:41 AM   #308
lazzer408's Avatar
WiFi?
Old 1st November 2010, 10:36 AM   #309
If the Linux based approach comes true then Wifi would be not a big deal by using a USB stick as Wifi hardware. Otherwise I rather don't see it.
Old 3rd November 2010, 08:27 AM   #310
lazzer408's Avatar
It needs WiFi for streaming Shoutcast.
Page generated in 0.08338 seconds (70.90% PHP - 29.10% MySQL) with 11 queries
