Go Back   Home > Forums > Amplifiers > Class D
Old 10th March 2010, 01:33 PM   #201
djQUAN is online now djQUAN  Philippines
Send a message via MSN to djQUAN Send a message via Yahoo to djQUAN
T-amps in the car. 41Hz Amp1 for the tweeters (Vifa XT25C90-04) and Amp2 for the Mids (Focal Polyglass 165V2S)
they only need this much heatsinking.
Old 18th March 2010, 08:56 PM   #202
h@kan is offline h@kan  Sweden
h@kan's Avatar
Helder tripath 2024 amp in $10 key cabinet
Old 18th March 2010, 09:03 PM   #203
h@kan's Avatar
Helder tripath 2022 amp in $5 key cabinet
Old 18th March 2010, 10:28 PM   #204
dudaindc's Avatar
Brilliant idea H@kan - just brilliant!
Old 28th March 2010, 08:12 PM   #205
chris661's Avatar
Default Amp6b
Hi all
Made this because I wanted to know how much power I actually needed. Turns out 15W will push my full rangers well into distortion.
The case is one from e-bay. £2.50 each. The plan is to make a buffered pre-amp, but for now, I'm using the PC volume control
Notice the heavily oversized heatsink, and heavy-duty carry handles.
iPod Touch (playing LossLess) > 4th order LR crossover @80Hz > Amp-6b > Fostex FE126eN in folded ML-Voigt Pipes
------------------------------------------------------------> Samson Servo 240 > W6-1139SG Tapped Horns
Old 28th March 2010, 09:25 PM   #206
Here's my diy Class D amp. It's based on an reference design of irf ( IRAUDAMP7D) together with three TAS3103a DSP's for sound processing (active crossover, volume control, equalizer, surround effects, spectrum analyzing, ...).
What started as a school project became a long term project. It's still under development.
current setup :
- 6 channel class d amp, 300 watt rms/channel into 4Ohm speakers.
- 4 PCM1802a ADC's
- 3 TAS3103a DSP's
- 1 6 channel PCM1606 DAC
- µC PIC24HJ256GP206
- 2 oldschool vu - meters with rgb backlight
- 1 240x64 pixels graphical LCD screen (blue blacklight)
- self made rotary encoder (old ball mouse hacked)
- 1KW transformer with 6 x 10000µF caps
future plans :
- rewiring the unit (little messy now)
- replacing PCM1606 dac by DSD1794a
- adding s/pdif receiver for digital sound.
Old 31st March 2010, 07:15 PM   #207
Kaasari is offline Kaasari  Finland
Old 31st March 2010, 09:00 PM   #208
h@kan's Avatar
Excellent design Kaasari!
Is there vent opening under the amp?
Old 2nd April 2010, 01:54 PM   #209
zog666 is offline zog666  Australia
Default quick and dirty TA3020 enclosure
Just to get my shiny new Connex Electronics TA3020 v3c module audible safely I've quickly cased it up in a discarded industrial power supply case I found. I was even able to re-use the "hospital grade" emi filter and a lot of the wiring that was left inside.
This is just a "get it up and running" build. still need to add power leds, standby mode, on/off switch, shielded input cables and other assorted frills.
Old 5th April 2010, 05:45 PM   #210
onis_uk is offline onis_uk  United Kingdom
My first ever amp build, after hearing my friends Tripath i just had to have one
Spec: Arjen helder TA2020, 3.5A SMPS and a custom made aluminium chassis
Page generated in 0.12194 seconds (70.45% PHP - 29.55% MySQL) with 11 queries
