This is my last build. I am going to replace the ADAU1701 board with the ADAU1466 DSP soon.
I have installed a second PSU in my Hypex Nilai amplifier, effectively making it a dual mono block.Hypex Nilai500DIY
Had to improvise to make it fit into a wall mounted BESTÅ cabinet from IKEA (WxHxD: 56x32x20 cm):
- 90 degree banana plugs and XLR's.
- External standby switch, the amp is resting on the front plate where it originally was.
- Removed the top cover for those nice LED's, an accidental PSU touch just clears my ears.. /s
- Adjustable voltage regulator in the green box to control the USB-powered exhaust fan.
More info can be found over at ASR: https://www.audiosciencereview.com/...ai-stereo-mono-kits-cases.48769/#post-1820706
Cheers!
