| Class D Switching Power Amplifiers and Power D/A conversion |
#101 |
First Try-out...
#102 |
Recently started all-over
#103 |
Find a way for PSU and Softstart
#104 |
Put it together in a box
#105 |
And voila, a working dual-mono amp... ;-)
#106 |
#107 |
4CH for car amplifier
#108 | |
That has to be one of the most stunning cases I have seen. Did you make those yourself?
#109 |
UcD topology based Amp 150w RMS
#110 |
Hi ANDYLASER,
No, I only supplied the electronics inside the housing in this case. The customer constructed his own housing. The front is made of 15mm aluminium on a CNC milling machine, the top and bottom are made of 4mm aluminium. All parts have been sand-blasted and anodized in black. The power switch is made of Niro. The display window consists of 3mm thick blue-tinted perspex. The "CLASS-D" lettering was printed on transparent foil and back-lit using 4 blue LEDs. The selected font imitates a graphical display. My own housings don't look as good as this
