Class D Amp Photo Gallery
Old 23rd December 2012, 05:34 PM   #591
redjr is offline redjr  United States
I never would have thought that a hanging configuration for PSU, amp, and crossover components would affect the sound. As you say, "cleaner clearer sound". Maybe you're onto something here.
redjr
Old 23rd December 2012, 05:42 PM   #592
Erlend Sæterdal is offline Erlend Sæterdal  Denmark
An amp do not belong on or in a speaker thats why. Resonances from the speaker to the amp.
Old 23rd December 2012, 07:10 PM   #593
makingmoney is offline makingmoney  United States
I agree. But I wanted to simplify audio things. I did a quick off the speaker then on the speaker by hanging. Very close sound to my ears so I hung them up.
Putting xovers on the floor is better than hard mounting them on or in speakers. Hanging them is about as good as having them on the floor. And they are hidden from view!
When building these speakers I did FR using inexpensive resistors and solen caps. When I finalized the xover I bought some Mills Rs and put in some teflon caps in a few places for solens. I could not measure a difference with my FR. My ears could hear the diff and my girl friend asked, out of the blue, "Wow. You really improved them."
I also don't think measuring FR hung vs unhung would show up in a FR. I don't think vibrations or noise affect FR much.
Old 30th December 2012, 09:21 AM   #594
Den.L. is offline Den.L.  Russian Federation
Car amplifier
Old 30th December 2012, 10:54 AM   #595
portomomo is offline portomomo  Europe
Great design and you touch a interesting theme: glass enclosures.
Like big ships in small bottles... anyone?
Old 1st January 2013, 10:38 PM   #596
jalejos is offline jalejos  Spain
Stereo amplifier Hypex with smps in 1U rack.
Old 2nd January 2013, 12:24 AM   #597
whaleman is offline whaleman  United States
whaleman's Avatar
Beautifully and skillfully done. Makes me want to try a Hypex. Lot of emphasis on the power supply, which is half the equation anyways. What are the specs or models for this setup?
WHALEMAN
The Cathedral Speaker Co.
Old 2nd January 2013, 09:01 PM   #598
Amplifier module: UCD180ST (180WRMS 8 Ohms, 154WRMS 4 Ohms)
Power supply: SMPS400A180
Enclosure: Modu Galaxy Maggiorato.
Old 4th January 2013, 10:00 AM   #599
bAD kLOPFER is offline bAD kLOPFER  Germany
4-Channel-L25D with A1000-SMPS from Cristi and two WLX-7 protection boards modded to work with DC-power. Case from Hifi2000.
I'm quite happy with the amp - no hum at all.
Old 5th January 2013, 10:48 PM   #600
JonSnell Electronic is online now JonSnell Electronic  United Kingdom
JonSnell Electronic's Avatar
Originally Posted by novec View Post
I'll join the gallery too, although I don't have anything yet... This is a four channel NewClassD amp to be driven with an active crossover. It's got 1300VA toroids and separate cap banks for each amp, 15000 uF Jensen 4-pole for the mid/high, and 2x 15000 uF for lows. I'll make the case out of 10 mm aluminium, with 3 mm top and bottom. Haven't desided on front design yet.
With a little luck, I'll have it done by Christmas
Now here's a thought. Why not change the design totally. Have the output stage directly fed by the mains power and have transformer fed (1k3KW transformers at 120kHZ have very little iron) loudspeakers with an opto coupled input stage.
Power is no problem.
If it was designed with high voltage MOS FET output transistors it could run nicely from a 440volt 3phase power supply!
I will show you my design when it is built.
Class D Amp Photo GalleryHide this!Advertise here!
Copyright ©1999-2017 diyAudio
