Class D Amp Photo Gallery
Old 10th October 2006, 10:08 AM   #21
SSassen is offline SSassen  Netherlands
SSassen's Avatar
Thanks,
That's just how I build all my gear, friends call it the Sander-Super-Nett-Verarbeitung, and that's coming from a bunch of German friends that have perfection written all over their builds already.
Best regards,
Sander Sassen
http://www.hardwareanalysis.com
Mediocre is not my middle name.
Old 10th October 2006, 10:20 AM   #22
TOINO is offline TOINO  Portugal
TOINO's Avatar
...O.C.C 1KW...
Old 10th October 2006, 11:36 AM   #23
BWRX is offline BWRX  United States
diyAudio Moderator Emeritus
BWRX's Avatar
Originally posted by TOINO
...O.C.C 1KW...
Care to share any more info about this module?
Brian
Old 10th October 2006, 12:36 PM   #24
drzhuang is offline drzhuang  China
Default Re: Re: It was called X-1
Originally posted by BWRX
It sure looks nice, but how did it sound? What kind of class d amp is it?
It sound good.
Modulator: classical PWM
Feedback: before LC filter
Power stage: N channel mosfets H bridge
Another kit of mono 500W@8
Old 10th October 2006, 12:42 PM   #25
Javin5 is offline Javin5  Switzerland
Hallo Sander
This is an outstandig implementation, perfect workmanship, clean design, very professional! Congratulations! As a beginner, with yet limited experience, may I ask two questions?
(1) You are using unbalanced inputs, rather than XLR. Did you compare the two and found no difference in performance? You just tied the unused input to ground?
(2) I see that you are using a power line filter. If I recall correctly, Bruno once recommended against it, because the Y-caps could cause ground contamination with power line noise. However, it all may depend on how grounding is implemented. Maybe you could shortly comment on this?
I'm in the process of finishing two UcD180AD monoblocks, a picture will follow shortly.
Kurt
Old 10th October 2006, 12:58 PM   #26
SSassen's Avatar
Kurt,
At that time I had more use for it as a single-ended amplifier, my current setup uses two Hypex UcD400s that do have a balanced input however. IMHO balanced inputs are superior to single ended, provided you carry this through throughout your system, only having one component with balanced in/outputs is rather pointless.
Well, that's correct, however I'm using a medical grade line filter which does NOT have Y-caps, so I do not have that problem.
Best regards,
Sander Sassen
Old 10th October 2006, 01:02 PM   #27
ssanmor is offline ssanmor  Spain
Some photos of a recently developed 6x400W amplifier, based on 6 coldamp BP4078 modules and 3 SPS80.
Height is only 44mm.
(don't know if I posted it before in other thread, sorry if so).
Old 10th October 2006, 01:04 PM   #28
and now the internals...
Old 10th October 2006, 01:09 PM   #29
fredos is offline fredos  Canada
The old D-amp 8000HVI.....
Fredos
www.d-amp.com
Old 10th October 2006, 01:10 PM   #30
SSassen's Avatar
That's a tight fit! isn't that little fan irritatingly loud?
Best regards,
Sander Sassen
Class D Amp Photo GalleryHide this!Advertise here!
