Go Back   Home > Forums > Amplifiers > Class D
Old 2nd October 2006, 01:59 PM   #1
alfsch is offline alfsch  Germany
Default strange effect in mosfet (h-bridge)
i built a simple half bridge with 2x irf730, v+ 60 volt.
for testing, no load, switching at 80khz (with about 1us deadtime).
so mosfets only switching...but they heat up! (just a little, about 10° or so).
(no rf seen on scope)
when coil (load) connected, mosfet stay cold !!
can anybody explain, why "free" switching mosfet, with lots of deadtime, can have power losses ??
Old 2nd October 2006, 06:40 PM   #2
Pafi is offline Pafi  Hungary
2 reasons:
- There is output capacitance.
- High dv/dt of hard switching can induce turn on impulse on opposit device.
"hard switching": high Vds when MOSFET starts to turn on.
"Soft switching", or "resonant switching": current of inductance makes voltage of drain-source alternate before MOSFET turns on.
Old 2nd October 2006, 10:49 PM   #3
a: outp. cap. is also here with load, so this should make no heat up
b: High dv/dt of hard switching can induce turn on impulse , great idea, indeed there is a 5v spike at the "wrong" gate
thanks to your help, i can sleep good now :-)
Old 3rd October 2006, 10:23 AM   #4
IVX is offline IVX  Russian Federation
IVX's Avatar
alfsch, some pics:
Best regards,
E1.
Old 3rd October 2006, 06:23 PM   #5
Cap is there, but with load it is charged and discharged by current of choke!
You're welcome!
Old 3rd October 2006, 07:35 PM   #6
ok, the caps make a (small) part of additional loss, your right.
#ivx: the spike is in the gate signal , similar to your pics :-(
well, ill try at 300v with coil ... seems to work, without heating up.
switching-spike at gate is still there, but only 2v peak, so no unintended turn-on should happen
SMPS 2KW full bridge strange signal Orcino Power Supplies 3 29th July 2009 11:27 PM
how ir2110 drives the high side mosfet in h bridge gowri Class D 2 10th April 2008 06:30 AM
Miller effect in H- bridge HINDI Class D 7 22nd May 2005 07:13 PM
Brazil, and some strange laws, not too much strange! destroyer X Everything Else 0 11th September 2004 12:38 PM
Pure Class_A Mosfet Bridge Amp Driver Workhorse Solid State 7 4th January 2004 03:19 PM
Page generated in 0.08757 seconds (77.11% PHP - 22.89% MySQL) with 11 queries
