Go Back   Home > Forums > Amplifiers > Class D
Old 2nd October 2006, 12:48 PM   #1
ShinOBIWAN's Avatar
Default Texas Instruments TAS5261
What do folks make of this new class D integrated solution?
http://www.ti.com/corp/docs/landing/...+EM+tas5261-em
Certainly looks neat and offers respectable performance.
Any products confirmed as using these yet? And do you think its of any interest to the DIY market?
Old 2nd October 2006, 01:24 PM   #2
ssanmor is offline ssanmor  Spain
Mmmm.
Max power established at a THD of 10%... very professional
Perhaps Hypex, LCAudio and us, Coldamp, should rate our products at 50% higher power.
Old 2nd October 2006, 01:53 PM   #3
ShinOBIWAN's Avatar
Originally posted by ssanmor
Mmmm.
Bit out of context that.
• 125 W into 8 Ω at <0.09% THD+N
• 220 W into 6 Ω at 10% THD+N
• 315 W into 4 Ω at 10% THD+N
The 125w into 8ohm and less than 0.1% isn't bad at all for an integrated solution. Certainly better than the Gainclones and competitive with the higher power t-amps.
Old 2nd October 2006, 02:22 PM   #4
Yes, that's right, 0.1% at rated power is quite ok, but I was only saying that specifying 300w at 10% is next to useless and a bit tricky (marketing stuff, anyway).
They would have seemed much more serious if they had said 180W at 1% 4 ohm (it must be something like that). Nothing more...
Old 2nd October 2006, 02:38 PM   #5
BWRX is offline BWRX  United States
diyAudio Moderator Emeritus
The max switching frequency of the TAS5261 is stated as 432kHz, while TIs other chips have a max of only 192kHz. They obviously did something different with this chip.
Brian
Old 3rd October 2006, 05:52 AM   #6
ericallan's Avatar
Default Re: Texas Instruments TAS5261
Originally posted by ShinOBIWAN
Any products confirmed as using these yet? And do you think its of any interest to the DIY market? [/B]
I've ordered some samples, if I can solder these, I'll report back here on the result. Should be interesting.
Old 3rd October 2006, 11:27 AM   #7
I´m amazed!
Groundloops's Avatar
@ericallan: I´ve ordered some samples too. Obviously PWM input is needed; did you figure out how to do that?
Old 3rd October 2006, 02:48 PM   #8
ericallan's Avatar
This page might help:
http://homepages.which.net/~paul.hil...enerators.html
Old 3rd October 2006, 03:14 PM   #9
You can generate a PWM signal from an audio signal using a simple 555 timer. You can either figure out how to do it from the datasheets or search the web for a schematic.
Do you have an evaluation board or have you designed a board for this chip?
Brian
Old 4th October 2006, 10:42 AM   #10
ericallan's Avatar
I'm wondering if this might do the trick:
http://shop.dataip.co.uk/products.html?prodid=81
New to DACs; After Some Research, is Texas Instruments PCM1794 the best DAC? elg2001 Digital Source 83 7th April 2007 01:16 PM
Is there any diference between BURR BROWN and Texas Instruments? -_nando-_ Everything Else 2 5th April 2006 08:19 AM
Texas Instruments resources for DIY jackinnj Everything Else 5 17th April 2004 02:08 PM
Page generated in 0.11692 seconds (79.40% PHP - 20.60% MySQL) with 11 queries
