Texas Instruments TAS5261
Old 5th October 2006, 06:07 PM   #21
FastEddy is offline FastEddy  United States
FastEddy's Avatar
Default Cool ...
" ... They just send me this stuff without asking ... "
See if you can get a prototype of their evaluation kit with boards ...
Old 5th October 2006, 06:34 PM   #22
pinkmouse is offline pinkmouse  Europe
pinkmouse's Avatar
I'm wary of asking for anything, they may well check my account and decide I don't deserve it!
Rick: Oh Cliff / Sometimes it must be difficult not to feel as if / You really are a cliff / when fascists keep trying to push you over it! / Are they the lemmings / Or are you, Cliff? / Or are you Cliff?
Old 5th October 2006, 07:09 PM   #23
FastEddy's Avatar
Default Of course you deserve it ...
... as long as you keep us all appraised of TI news & new releases, etc. ... you are doing promo work for TI = everyone is happy.
FYI: your picture looks like a 36 pin SM to me ... and the heat sink should just clamp on top.
Old 5th October 2006, 09:09 PM   #24
-_nando-_ is offline -_nando-_  Brazil
Send a message via MSN to -_nando-_ Texas Instruments TAS5261
Let me ask you,
The powerm and output stages are ok, no problem at all.
But what do I need (part numbers please, then I can check how much they are) to make this a complete amplifier with analog signal input, to be driven by mp3 players etc ?
Fernando
Old 5th October 2006, 09:48 PM   #25
BWRX is offline BWRX  United States
diyAudio Moderator Emeritus
BWRX's Avatar
Default Re: Of course you deserve it ...
It is a 36 pin slug up package. It's the same pacakge as that of the Tripath TA2021B. Does anyone need a layout made for this chip? I already have a footprint created for the package and can probably do better than the layout they provide in the datasheet.
But what do I need (part numbers please, then I can check how much they are) to make this a complete amplifier with analog signal input, to be driven by mp3 players etc?
You need the front end. At a minimum you need non-inverted PWM and inverted PWM drive signals and a 12V supply for this chip to function. You will need to enable the chip too, which is as simple as pulling the enable pin low (it's an active low).
Brian
Old 5th October 2006, 10:40 PM   #26
FastEddy's Avatar
Default But of course ...
BWRX: " ... It is a 36 pin slug up package. It's the same pacakge as that of the Tripath TA2021B. Does anyone need a layout made for this chip? I already have a footprint created for the package and can probably do better than the layout they provide in the datasheet. ..."
But of course we would like a fresh layout ... (If possible consider extra positions & thru holes for such things as "snubbing" caps on the PS rails, etc.)
That's a lot of work, isn't it?
If not, then layout plus parts list would be nice ... but I would hope that TI's recommendations would be followed. The only thing I am going to do to the design initially is to limit the power so as to hold down the full power THD into 8 ohms to something below ~=0.07% (if possible in reality).
-_nando-_ " ... what do I need (part numbers please, then I can check how much they are) to make this a complete amplifier with analog signal input, to be driven by mp3 players etc ..."
Yeah, me too! ... and got a recommendation for a board source? (I'm sure there are plenty of links here for this, but I would like to hear your recommendations.)
My goal is to make a vquality, cost effective, high efficiency Class-D amp. Eventually I want this combined with a low profile, higher efficiency switching supply ... aiming for a light weight, 100W+ / dual channel for use on stage as guitar/PA/monitor amp without embarassment = clean as a whistle. (Pre-Amp might be something like this: http://www.mesaboogie.com/Product_In...ctoPreAmp.html )
(I may have one of my employees do the soldering 'cause of my tired 60+ year old eyes ...)
Old 5th October 2006, 10:54 PM   #27
BWRX's Avatar
Default Re: But of course ...
It is. That's why most people don't do layout work for free Usually it helps to have a general idea of components specs and ratings so you know what size parts to use and can get a general idea of where to place components. I'll see what I can come up with in my minimal free time since I already have one of the hard parts completed.
Brian
Old 5th October 2006, 10:59 PM   #28
FastEddy's Avatar
Default limited resources ?
" ... I'll see what I can come up with in my minimal free time since I already have one of the hard parts completed. ..."
Look, don't strain your ketchup here. the TI layout can be used without too much bother ... besides, when the time comes, there may actually be a market for this beast = "Anything worth doing, is woth doing for money ..." - Alfred E.Newman / Mad magazine.
Old 5th October 2006, 11:04 PM   #29
BWRX's Avatar
Don't worry, I won't strain myself for something I won't even be building (at this moment anyway). There are some improvements that can be made though. Like I said above, the pin outs for this chip are nice in that they allow for a nice layout.
Some things worth doing, i.e. speaker/amplifier/electronics projects, are worth doing by yourself, for yourself
Brian
Old 5th October 2006, 11:52 PM   #30
thomaseliot is offline thomaseliot  Europe
Let me ask you,
Fernando
Maybe you need something like this:
http://focus.ti.com/docs/prod/folder...t/tas5012.html
It is a PurePath(TM) PWM Controller: I2S or DSP input -> PWM output.
Input from 44.1 to 192khz , 16 and 24 bit, automatically selected. There are modules up to 8 channel input.
Texas Instruments TAS5261Hide this!Advertise here!
New to DACs; After Some Research, is Texas Instruments PCM1794 the best DAC? elg2001 Digital Source 83 7th April 2007 01:16 PM
Is there any diference between BURR BROWN and Texas Instruments? -_nando-_ Everything Else 2 5th April 2006 08:19 AM
Texas Instruments resources for DIY jackinnj Everything Else 5 17th April 2004 02:08 PM
