| Class D Switching Power Amplifiers and Power D/A conversion |
#211 |
I'll go for two Brian.
#212 |
I received an email yesterday evening from TI that my two TAS5261 samples are shipped
So my guess is they will be delivered to me monday morning. Brian, I will send you a PM on the parts matter. Regards |
#213 |
diyAudio Moderator Emeritus
Sounds good. I'm working on a wiki page right now to help me stay organized and to allow people to edit the quantities of what they want in the table. I'll post a link to it when it's done.
Brian |
#214 |
Here's the wiki page: http://www.diyaudio.com/wiki/index.p...ards+and+parts
Let me know if any more information/explanation is needed. All quantities are preliminary as I have just filled in names and quantities for those interested. Please change them as you see necessary.
Brian |
#215 |
Nice, you could put there BOM xls file. One question about T106 core: while looking for it I found out that you still have to give more details - there are at least two different versions. One is made of material #2 (whatever that means), and the other of material #3. The first one has AL=13,5 uH/m2 and the other =45 uH/m2. Which one is the correct one?
Marek |
#216 |
You can find the MPP T106 cores listed here: http://www.cwsbytemark.com/prices/mpp.php
The ones I will order are part number CM270060. They're made of molypermalloy (MPP) with a permeability of 60. Here's a link to the technical data for the T106 cores: http://www.cwsbytemark.com/CatalogSh...20files/40.pdf
Brian |
#217 |
It takes 2.5 feet of 18ga wire to get 18 turns on the T106 cores (with some air gap between windings). The finished inductor should look something like the attached photo. I'm changing the wire gauge from 16 to 18 because 18 is hard enough to wind and shouldn't make much difference over 16ga.
I believe Thomas had measured the inductance of his T106 MPP cores (permeability of 60) to be about 11uH with 13 turns of 16ga wire. It shouldn't be much different with 18ga wire.
Brian |
#218 |
Cool, count me in. Even I can make coils like that ...
#219 |
Yep, 13 turns on those cores isn't hard to do. It is hard to keep the 16 and 18 ga wire flat to all sides of the core. At least you'll have a hard time breaking either the core or the wire if you pull really hard.
I also tried winding a core with 3 0.7mm diameter wires side by side. This tried my patience a little but it can be done and looks pretty cool. Don't know if it would sound any better than the single 18ga wire or not but the windings are much closer to the core all the way around.
Brian |
#220 |
As predicted, the two TAS5261 chips arrived today
![]() Muchos gracias TI. Regards |
| New to DACs; After Some Research, is Texas Instruments PCM1794 the best DAC? | elg2001 | Digital Source | 83 | 7th April 2007 01:16 PM |
| Is there any diference between BURR BROWN and Texas Instruments? | -_nando-_ | Everything Else | 2 | 5th April 2006 08:19 AM |
| Texas Instruments resources for DIY | jackinnj | Everything Else | 5 | 17th April 2004 02:08 PM |
| Page generated in 0.10692 seconds (81.01% PHP - 18.99% MySQL) with 11 queries |
