Trends Audio TA-10: Modding Potential?
Old 16th December 2010, 08:30 AM   #991
JRKO is offline JRKO
JRKO's Avatar
Send a message via AIM to JRKO
Default Headphones
Does anyone know if the Trends T10.1 can be used to drive headphones?
If I'm not making noise, I'm making something to make noise
Old 16th December 2010, 09:10 AM   #992
jonclancy is offline jonclancy  United Kingdom
From what I remember, it is not normally possible, due to grounding. If you had a balanced headphone set up (with separate grounds) then it might work. If the L/R channel grounds meet, I believe it goes phuuuttt!!!
John Linsley Hood Ripple Eater GB Part One made 729 for Cancer Research UK. Thanks for your support!!!
Old 16th December 2010, 10:27 AM   #993
JRKO's Avatar
Thanks jonclancy. I have a blalnced cable for my HD650's. Any idea how I wire the amp for balanced headphones?
Old 16th December 2010, 11:03 AM   #994
I'm afraid I would only be guessing... so won't offer a view I thought this might have been covered earlier in this thread, IIRC.
Maybe an email to Trends might help?
Cheers
Jon
Old 16th December 2010, 12:29 PM   #995
Pano is offline Pano  United States
Pano's Avatar
I've done it with balanced headphones. But I use a big resistor network (L-Pad) to bring the level way down. This is very important. I believe, but am not sure, that you could use a resistor network to run unbalanced phones by keeping the negative speaker terminals at least 4 ohms apart.
It's not that great a headphone amp, but if you already have one and want to build the L-Pad, then it may be worth a try.
Take the Speaker Voltage Test!
Trends Audio TA-10: Modding Potential?Hide this!Advertise here!
