| Class D Switching Power Amplifiers and Power D/A conversion |
Hi to all,
I am italian and i am very interesting in DIY project. ![]() I would like to ask you some questions and evenctually some best practices for building my first project based on CHARLIZE from DIYPARADISE.COM. Please, try to understand my bad english. ![]() I bought the kit because i was very curious about Tripath and having to sonorize a small home studio i thinked that it was a good solution. Googling around and also inside the forum i found some good review of the kit. This is the setup PSU switching Skynet 8080 CAPS Nichicon 10000 Uf/63 Volt Charlize with air core inductors Alps Blu 50K Golden RCA connectors Golden speakers connectors OFC calble for connecting CHARLIZE -> SPEAKERS CONNECTORS CAT 7 Cable for connecting RCA - ALPS - CHARLIZE Solder with high percentage of silver HIFI2000 Enclosure Charlize will play a chain based on: .CD Marantz CD63-MkII KI .Indiana Line 4.30 .Signal Cable YANXING OIL INJECTED (Attached you will find a photo of this strange cable) .Speaker Cable TNT-Star I would like to have your opinions on such type of configuration and on the components selected. I have a doubt about AC Line filter: Is it right to use it or not? If yes, why? Thank you very much for every reply Bye Fabio |
#2 |
space charged
You will get more responses if you post this in
the "Class D" Forum. diyAudio Forums diyAudio Forums > Top >Amplifiers >Class D Cheers, |
#3 |
Hi Fabio,
I moved your post to the Class D amp section for you ... -Chris |
#4 |
I think you won't be disappointed, not to say there are better options...
![]() The AC line filter smooths out any possible interference on the 50hz AC power on the net, use it if not only to improve the audio than it might save your equipment. I don't think it will be very necessary... Some people are not so enthusistic about the Charlize too: Underwhelming Charlize sound
Max. cone displacement can be several foot on any speaker!Too bad it can be done only once......
#5 |
Any1 know the Newclassd ?
Can i have some informations ? Thanks |
| A Tripath TA3020 based amp | ehien | Class D | 48 | 27th July 2010 03:55 PM |
| HELP tweaking my tripath based amp! | packman | Class D | 6 | 1st November 2008 05:28 PM |
| My first DIY project based on tripath - Dyparadise CHARLIZE | fosforo | Class D | 1 | 3rd October 2006 01:06 PM |
| FR125S + Tripath 2020 Charlize, am I crazy? | eVITAERC | Full Range | 4 | 6th October 2005 02:37 PM |
| Dr. Amp Tripath based amplifier | pepolman | Class D | 8 | 6th August 2005 06:28 AM |
| Page generated in 0.08178 seconds (81.28% PHP - 18.72% MySQL) with 11 queries |
