Go Back   Home > Forums > Amplifiers > Class D
Old 14th October 2006, 05:22 AM   #81
Yeah leakage is higher in new caps, but quite frankly, I think that's a load of ****. The little bit of extra leakage is just not going to fry a fuse.
I am now using a 6.3A fuse (yes, our outlet is 230W), and it seems to work fine. But I definitely will have the amp. checked out when I have the time.
Thanks for the advise!
Old 15th November 2006, 09:34 AM   #82
Originally posted by lucpes
You can get away with as little as 1.6 uf for a highpass corner frequency of 1Hz on the input caps at the module. 6uf would be 0.3Hz and I don't see the point of going that low... (the series capacitor and the 100K input resistor to ground form a highpass filter) I have 1uf coupling caps at the preamp end and it works just fine...
Are you sure you can use such low capacitor?
DIY Stands-Standanddeliver? i Stood, hope i delivered magma Everything Else 17 27th July 2009 01:15 PM
ZV9 upper limits??? sandyhooker Pass Labs 4 27th December 2008 04:24 AM
airlinktransformers are not picking up the fone and have not delivered my toriod joka22 Chip Amps 11 28th August 2008 10:26 AM
.wav file limits? Netlist Digital Source 5 2nd December 2006 08:16 AM
BZLS PS limits? protos Pass Labs 4 23rd January 2004 04:06 PM
Page generated in 0.09027 seconds (63.80% PHP - 36.20% MySQL) with 11 queries
